Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: TPMS disable
    Oct 2019
    So let me get this straight....the sensor is located to the rim?...so you can rotate four around the gen4...no probs but the spare must be maintained as a spare?
  2. #12
    May 2018
    West Gippsland Victoria
    Quote Originally Posted by Xplor8 View Post
    Well yeah sort of , the sensors are attached to the valve inside the tyre/wheel I believe , can't say I have seen one .
    You can buy and install a extra sensor and fit it to the spare but when you fit the spare you have to take it to Nissan and get them to code it so it will show on the dash , the dash can only show 4 sensors , you would have to do that every time if doing a 5 tyre rotation , unless you bought ya own scan thingy .
    But my Nissan dealer said I couldn't do that because the extra sensor would interfere with the others and none would work but they are full of it because others have done it .
  3. #13
    Quote Originally Posted by Jackofjr View Post
    snip...
    Yep, total bullshit.
    The tyre has to be rotating to "wake up" the sensor, and the sensor unique ID has to be "registered" on the TPMS which has a max of 4 at anytime... none of which can happen with a 5th sensor on a spare, it is asleep and not registered on the TPMS
  4. #14
    Oct 2019
    Sooooo...
    .if im rotating my 4 tyres..keeping the spare as a spare im ok....(sounds screwed up i know)
    If i wanna rotate the spare without the internal valve tpms i gotta ask my local shop to change the valves ???....so wont need to take it to nissan as the head unit monitoring the tpms will still see that vale spinning like all four should ...(swap vales each rotation)
  5. #15
    May 2018
    Sooooo...
    Yes that would work but don't ya think that would be a pita , probably better off just buying a extra sender and getting the Nissan dealer to register it each time , depending on the dealer I guess ,
    My dealer I think it would be to much bloody trouble even though it's only a 5min job .
  6. #16
    Oct 2019
    Yep totally...
    Agreed...particualy important to rotate just the fouras the 62 gets older when peeps start doing their own servicing etc?
  7. #17
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Quote Originally Posted by Alpha View Post
    I know I am not answering your question, but I thought I can share some ideas indirectly related
    No need for a spare tire
    I do two things
    1- carry a portible compressor to inflate the tire and usually for 99% of the punctures, the tire can hold pressure for few hours.
    2-maintaining a spare tire is more expensive than a towing truck these days that is only if the tire can not hold pressure which I had few times in my life.
    But for heavy off-road people that maybe exposed to unsafe situation, then I understand even two spare tires are justified
    Unless you never left the inner city, this advice is pretty irrelevant and potentially dangerous for Australian drivers mate.
  8. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    jack (1st October 2020)
  9. #18
    May 2016
    lower west victoria
    30 Post(s)
    Ok Mr. Jules Verne
    I crossed parts of the empty quarter.
    But you seem to reply without understanding.
    I think we all understand now mate.
  10. #19
    176 Post(s)
    Seeings as how this thread has been 're-awoken' ........ am I correct in assuming that these Nissan supplied tyre pressure sensors are fitted inside the tyre & need to be re-programmed every wheel rotation?
    My aftermarket TPMS with the sensors fitted to the valve stems has a specific sensor for each wheel position, so the sensors get moved.
    Just asking for my education - are all internal tyre pressure sensors somehow re-programmable? If not do tyres need to come off the rim every rotation?
  11. #20
    Dunno if it helps overall Cuppa but specific to the Y62...
    I have 5 x Ridge Grapplers and 5 x Factory all with nissan internal sensors (so total of 10)
    All internal sensors have a unique digital ID no matter who makes them.
    The Patrol TPMS processor will only store 4 sensor ID's at any time
    -If I rotate any tyre off the vehicle (eg 5 wheel rotation thru the spare) or swap the entire set the ongoing sensor/s has/have to be registered with the TPMS.
    -If I rotate the tyres on the vehicle (eg a 4 wheel rotation excl the spare) no dramas
    Because the sensors need to be "woken up" to register with the TPMS there are specialist electronic kits (freely available but not cheap) and a "one off" registration procedure that has to be carried out each time a sensor (IE wheel assy) is taken off 1 of the 4 corners of the vehicle.
    Not all sensor manufacturers use the same frequency so not all test kits necessarily work on all vehicles so Nissan or the Tyre mob if they have a compatible kit need to do a registration procedure
    Once 4 sensors are registered all is good until the next tyre removal.
    Bottom line is even tho all 10 sensors of my sensors have been registered at one time or another on my vehicle only the last 4 registered road driven tyres are monitored (sensors registered on the TPMS and after each start woken up by exceeding 20 KPH momentarily).
    If any 1 or more are rotated off/replaced/fail the TPMS knows it is "missing" but will not automatically delete the "missing" one and replace with the current sensor data.
