Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 61
Thread: DIY Wheel Bearing Adjustment.
  1. #31
    Thanks Darren.
    What you said makes sense. I also wondered , if I lost a weight or something on the rear left ( which is now on the front left ) , why I didn't get any wobbles or anything before roation. But like you said bringing it to the front will exacerbate the issue. Makes sense.
    Also sorry for thread crapping about my issues. This is after all bearing tightening DIY guide.
    Sent from my SM-N910G using Tapatalk
    PPl dont normally need a balance on the rear wheels.
    but most do when buying a set of tyres, so in theory your wobble may
    return next rotation as you are again introducing a rear wheel to the front.
  2. #32
    Oct 2015
    Mid North Coast
    excellent so easy to follow thanks heaps bobin 51
  3. The Following User Says Thank You to bobin51 For This Useful Post:
    MudRunnerTD (30th January 2018)
  4. #33
    Hmm , something else I need to check.
  5. #34
    May 2016
    lower west victoria
    30 Post(s)
    Brilliant stuff @MudRunnerTD, this is exactly what I needed to see to learn what to do should I need to tighten these things up on trips etc.
    Thanks again.
  6. #35
    May 2016
    lower west victoria
    30 Post(s)
    Thanks again.
  7. #36
    177 Post(s)
    Hey Darren @MudRunnerTD .
    Decided to triple check and nip up my bearing before I replace panhard bushes and fit a new draglink.
    When I took off the passenger hub I noticed a small pool of oil and/or water at the bottom. It was hard to tell whether it was more watery or more oily.
    I'm assuming its either the seal from the diff end ( if oil leak) has a weep or water may have gone in behind the hub somehow. I have done 10+ water crossings since my last re-check.
    I'm just brainstoming here mate. Thoughts ?
    In the photo you can see the small pool in front of my finger.
  8. #37
    84 Post(s)
    Take the lowest bolt out of the bottom swivel bearing plate. If there is oil or water it should come out there. I always run a small bead of silicon between the hub and the hub lock to stop water ingress.
  9. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    Hodge (2nd October 2019), MudRunnerTD (2nd October 2019)
  10. #38
    @Hodge yeah take out one of the lower king pin bearing bolts and see if anything drains out. If nothing your good to go.
  11. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  12. #39
    177 Post(s)
    Cheers fellas. Will crack one open tomorrow..
    So, let's assume it's oil.
    That's the axle seal right?
    Which will need a full bearing kit put through?
    No, it will need a new axle seal. Will and Should ate 2 different words mate 😉
    If the seal is gone and you ha e never done a rebuild then it really will make a difference. How many kms has your car done mate?
  14. The Following User Says Thank You to MudRunnerTD For This Useful Post:
