Results 1 to 9 of 9
Thread: leaf spring lift
    Sep 2019
    leaf spring lift
    So ive been doing my research and it seems that the go to lift height for leaf sprung rear is only 50mm. While 50mm is fine, if i can go higher i just might. So how do people lift any more then 50mm in the rear end on leaf? Is it just as simple as extended shackles( yes i know they are illegal) or more leaves in the pack. This is what info i could find, if im wrong, please let me know because id like to gather as much info as i can before i go buying anything. Still learning about the patrol suspension setup.
    G’day Stump mate!
    Honestly not trying to be rude, a very happy DX leafy owner also workwise over the years too.
    Coily arse end utes do well outperform beasts yet lack some extra 400kg legal payload.
    Besides, Old Man Emu, we did in the olden days benefit from a resetting mob in Bayswater Victoria, Spicer Springs IIRC?
    Sep 2019
    All good mate. No offense taken. Just want to learn as much as i can before buying suspension. So pretty much what your saying is that im pretty well limited to 50mm lift unless i do a coil end rear conversion?
    198 Post(s)
    No experience with leafy Patrols, but OME leaves in a 75 series Troopy and a 60 series wagon, 'medium to heavy rating', outstanding result. Only issue with the front springs were they were a bit too long and it was easy to invert a spring hanger. Great articulation and ride, held the load well.
  5. #5
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Extended shakles. I have no idea about the legality of them though. Although anything above 50mm will need an engineer to look at it depending which state you're in anyway.
    Something like this: https://rover.ebay.com/rover/0/0/0?m...2F263894505465.
  6. #6
    For sure, I believe only total 75mm overall lift from OEM specs IIRC is ADR standard allowed Nationwide these days maybe?
    Can be a combination of tyres/suspension/body lift to a maximum of 50mm suspension/body and ‘generally’only a 25mm tyre OEM size increase. (1” yanky = 25.4mm please remember)
    Plenty of unfortunate trackside tickets witnessed written for say 1” lifts & pre Y62 35” tyres driven.
    In regards leafy lift hangers, used to illegally make our own plates olden days for Toyoda FJ’s and the like. The geometry of say a 6” hanger with midway bracing in reality only gave a half that raise at best and caused too much leafy front/rear FJ spring stress.
    Happier Nissan future leafy days found spring resetting from a reputable mob got the 50mm needed at half the price of OME, although now would personally ring them for a good longer term required reliability
  7. The Following User Says Thank You to MB For This Useful Post:
    0-TJ-0 (11th September 2019)
    Sep 2019
    Thanks for the feedback guys. So after doing some looking around ive found info on dobinsons, king springs and ome. Are there any other companies that i should check out? Or is there a thread i should go and check out on this forum?
    400k in a leaf troopy, first Id put greasable shackles in a must have for leafies
    extended shackles youll need to do front and rear. I ran this set up for years with no probs.
    twin diff locks 33" muddies and a 350 chev motor saw it near unstopable
    MB (28th September 2019)
  11. #9
    Ran very similar too John mate! Still reckon your current GU coily even if still stock maybe like our family LSD rear only would carefully ‘walk’ all over our old trucks Legend
