Page 15 of 83 FirstFirst ... 1314151617 ... LastLast
Results 141 to 150 of 824
Thread: Harrop 2300 supercharger to Optimiser 6500
  1. #141
    198 Post(s)
    Yeah there is just to much flow returning to that little reservoir but it is only a thought. I know BD are fantastic are supplying secondhand crap
    Yep, finding this out, along with very limited substantiated engineering. I am looking at replacement clutch as mine is undernourished for sure, but think I will get it dyno'd first to get a real understanding of what i need capacity wise because BD have expanded the capacity by 50% on the same clutch over the last 3 days - must be due to the sunshine over in WA!
  2. #142
    198 Post(s)
    OK, just received the new PS pump. Could I ask a favour please of any GQ Patrol owner, to take a photo of the hose connections at/to the PS pump and also the reservoir. I am looking to confirm the pressure and return lines orientation. I am pretty sure I have it correct, however would like to confirm it before starting the mission of replacement next Friday. The pressure line from the pump should have crimped fittings I think and the return lines simply hose clamped.Thanks in advance.
    The pressure line I believe is the one shown with the crimped hose still connected to it - If this could be confirmed it would put my mind at rest. This is the hose I connected to the pressure port on the pump.
  3. #143
    83 Post(s)
    Sorry it took so long. The high pressure side is is circled in both pics. On the steering gear it is the one towards the front. On the pump it is towards the passenger side.
  4. #144
    198 Post(s)
    Thanks Craig, appreciate it. I assume front of vehicle is bottom of image?
  5. #145
    83 Post(s)
    Edited above post.
  6. #146
    198 Post(s)
    Edited above post.
    Gotcha, this aligns with the image i posted earlier,now I am doubting if I have plumbed this up correct or not - simply cannot recall the detail - so will have to stew on this until next friday, but then I can't see how the ps would have worked in the first place and why it didn't fail immediately if it was hooked up backwards?
  7. #147
    83 Post(s)
    The bottom hose from the reservoir goes to the low pressure side of the pump.
  8. #148
    83 Post(s)
    Dunno, Phil. The blue hose is the suction inlet. I suppose if it was plumbed wrongly, it might have been pumping high pressure fluid into that.
    If you were turning the steering wheel while the vehicle was on a jack, then not much pressure was applied. On the road, with higher pressure and load it would have caused a higher pressure to be generated at the seal. All conjecture at this point, though.
  9. #149
    198 Post(s)
    So, when you look at the lines that run across the front of the car from drivers side to passenger the return to the drivers side, are they on the low or high pressure side of the system?
  10. #150
    198 Post(s)
    OK here is what I have and believe it is correctly configured.PS Schematic.pdf
