Results 1 to 9 of 9
Thread: GQ Specific Issues and Spares for Trip
    Expert Jimmyboyjr4's Avatar
    Penrith, NSW
    Hi all,
    I'm just making a list of spares and repair items for my trip in two weeks.
    Does anyone know of specific GQ trouble areas I should watch out for and take spares in case?
    My friend on the trip is advising me to pack so many spares it would rival my fuel budget for the trip.
    JB< do a search, there are a number of posts on this subject here.
  3. The Following User Says Thank You to PeeBee For This Useful Post:
    Jimmyboyjr4 (9th August 2019)
    334 Post(s)
    Quote Originally Posted by Jimmyboyjr4 View Post
    Hi all,
    Where are you going? what engine? what is your mate driving? How long are you going for?
  5. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Jimmyboyjr4 (9th August 2019), Rossco (9th August 2019)
    Penrith, NSW
    Yeah, I had a read through quite a few of the old ones, and I used them to formulate my list - commons spares and all that.
    Just wanted to know if GQ's had any common offroad faults that would require I buy parts for before I leave. As a far as I can see, there's not much I think I'll need.
    Penrith, NSW
    Red Centre Way, Oodnadatta Track, Alice Springs. However, thats from NSW - about 6,500kms in total.
    Maverick/Patrol 4.2 Diesel N/A
    My mates driving a colorado, not to many common spares.
    Only a few weeks, but there will be lengths of time that a quite remote.
    Sorry, should have included all of this before.
    334 Post(s)
    Kool.
    Replace all of your belts and Hoses NOW. keep what is on the car as Spares. Makes No sense to take new belts and hose away as spares. dont wait for failure. Fuel Filter for sure. A couple of trailing arm bushes, a couple of radius arm bushes. a couple of shock bushes. Zip Ties, Gaffa Tape and WD40. #SendiT
  9. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Jimmyboyjr4 (10th August 2019), Rossco (9th August 2019)
  10. #7
    Make sure your tyres are good and adjust pressures accordingly a speedy seal kit or similar is not a bad idea and compressor. Most problems from this kind of touring comes from too much weight and corugations for hours on end. Make sure the Colorado isn't ridiculously overloaded see a lot of dual cabs with bent chassis out that way, if it's reasonably packed will be fine. All the best, enjoy ! . .
  11. The Following User Says Thank You to Rossco For This Useful Post:
  12. #8
    Penrith, NSW
    Kool.
    As always guys, thanks for the information - I'm really grateful.
    In terms of the various bushes you mentioned, this is what I was thinking:
    Trailing arm bushes x 2
    https://patrolapart.com.au/product/g...iling-arm-bush
    Radius arm bushes x 2
    https://patrolapart.com.au/product/n...-bush-diff-end
    In terms of shock bushes, however, which would be best suited for carry as a spare? My shocks are stock, by the way.
    https://patrolapart.com.au/product-s...ria=shock+bush
    Everything else I've noted, and thanks to the both of you for your help!
  13. The Following User Says Thank You to Jimmyboyjr4 For This Useful Post:
    Rossco (11th August 2019)
  14. #9
    May 2016
    lower west victoria
    30 Post(s)
    If I were buying bushes for spares I'd fit them before I went away, then I know everything should be OK. Do the changes at a minimum 4 weeks before you leave and make sure you drive the vehicle as often as possible to make sure all the new fitted bits and pieces are fitted properly.
    If you replace your hoses, I wouldn't bother taking spares, new hoses shouldn't wear out or burst.
    Cable ties are good for lots of things, but you'll need wire if your exhaust hangers break.
    Engine oil, don't know if you'd need brake fluid??
    I carry 2 spares, but I can't remember the last time I had a puncture. That being said I always pack tyre plug kit.
    The very best thing you can do is to keep your vehicle as light as possible, you really don't need alot of stuff. It reduces the strain on your vehicle and also helps with fuel consumption.
    If you run big tyres, maybe look at fitting something smaller eg: 32s instead of 35s.
    HtH
