Results 1 to 5 of 5
Thread: headligths gq patrol
    Jul 2019
    Hi rhs headlight goes out randamly,when it goes out the highbeam light on dash lights up ,both lights do work on highbeam anyone had this probelm before thanks in advance
    Common problem and usual culprit is the stalk switch for the headlights is dirty, next most common is a bad earth or melted plug on the headlights.
    Jul 2019
    thanks will check out
    84 Post(s)
    If it hasn't got relays fitted, I recommend doing it as a worthwhile mod.
  5. The Following User Says Thank You to mudnut For This Useful Post:
    johnbra (26th July 2019)
    84 Post(s)
    The only problem with the above circuit is that both lights will go out if there is a problem. I think I may shift the low beam circuit breaker to after the relay so it is in line to one side low beam. I will add another breaker inline to the other side so it won't cause a blackout if there is a fault.
