Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Not sure what this is (catch can?)
    Apr 2018
    new owner of a 2002 Td42 coil cab probably a stupid and obvious question but I have been looking through my manual but I can’t find this catch can looking thing in the book as seen in the photos. Is it a aftermarket catch can? If anyone knows it would be greatly appreciated
    Apr 2018
  3. The Following User Says Thank You to Declan For This Useful Post:
    Yeti's Beast (18th June 2019)
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    It’s a vacuum canister. Don’t touch!
    Proud BTrol Owner
  5. The Following User Says Thank You to Yeti's Beast For This Useful Post:
    Declan (19th June 2019)
    476 Post(s)
    As above. They are vacuum tanks. They hold vacuum in them for your brakes and clutch as the vacuum pump alone is not enough. So vacuum is stored in them pretty much.
  7. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Declan (19th June 2019), Yeti's Beast (18th June 2019)
  8. #5
    Aug 2016
    Jimboomba
    4 Post(s)
    For some reason they were on pre 2003 models only. Must of changed something in series 3.
    They also have a small canister for the valve in the throttle body. Again series 3 on didn’t have it
    Proud BTrol Owner
  9. The Following User Says Thank You to Yeti's Beast For This Useful Post:
  10. #6
    476 Post(s)
    Proud BTrol Owner
    Yeah not sure why. They might have changed the style of the vacuum pump or something. Or just worked out the tanks wern't really needed...
  11. The Following 2 Users Say Thank You to mudski For This Useful Post:
  12. #7
    Aug 2016
    Jimboomba
    4 Post(s)
    I blanked the Egr thanks to the part supplied by @mudski and removed the Swirl valve while I was at it and blocked off the vac pipe going to it.
    My mate has a 2000 model and we can’t work out why both cars have different vacuum systems.
    Proud BTrol Owner
  13. The Following User Says Thank You to Yeti's Beast For This Useful Post:
  14. #8
    Not sure what motors everyone’s trucks above are running and or previous to conversions etc... I can only nuffy assume that from quite a few owned 1999-2002 4.2 diesels always same factory twin cannisters must’ve required extra vacuum storage found by Mr Nissan too late? Petrols and quite possibly 3.0L diesels possibly had enough suck for one cannister only maybe to meet ADR’s?
  15. The Following 2 Users Say Thank You to MB For This Useful Post:
    Declan (19th June 2019), mudski (23rd June 2019)
  16. #9
    Apr 2018
    Thanks so much guys that makes much more sense!
  17. #10
    Expert dpetersen's Avatar
    Jan 2015
    Watarrka National Park
    6 Post(s)
    Proud BTrol Owner
    Mines a series iv, 4.2 tdi and it’s got one
    2006 4.2 tdi wagon
    Plenty more to come!
