Results 1 to 6 of 6
Thread: Oil cooler for auto trans
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Has anyone installed an oil cooler for their 3.0 Di Auto transmission?
    How difficult was the job?
    Don't they already run one through the radiator?
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    I was of the belief that was later series. I have the 2002 GU3.
    I could be mistaken though so I will go have a closer look.
    Quote Originally Posted by Mc4by View Post
    I will be easy to tell. If you see two steel pipes going into the bottom of the radiator. You have a cooler.
    Mc4by (20th June 2019)
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    The ZD30 already has a good sized alloy trans fluid cooler. It's roughly twice the size of the factory TB45E trans cooler.
    A good addition is a trans fluid temp gauge if you're towing.. or using it a bit harshly.
    John
  7. The Following User Says Thank You to jff45 For This Useful Post:
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Thanks I can see the pipes so I will stop worrying about not having one.
