Page 6 of 6 FirstFirst ... 456
Results 51 to 56 of 56
Thread: Anyone using snatch rings?
  1. #51
    I was watching a youtube clip on these units in action, from a distributor in the UK from memory, and what I noticed was the soft shackle was fitted with a wear sleeve and the donut rotates directly on that surface rather than the rope. I thought that would probably be enough to get me to purchase one as the interface surface between the rope and ring is my only concern. I think they are a really simple device and improvement in a lot of conditions, but still holding onto the snatch block until I see some more feedback.
    You thinking like these BS 15Ton
    Again I stress do not use these with my recovery points as they were not designed for soft shackles.
    Ive noticed Road Safe selling soft shackles with copies of my recovery points, again DO NOT use them.
    if you must first use a shackle so the soft shackle has a smooth round surface to work on
  2. #52
    Yes TD, however like the double legged units better, I have some of the singles but have not used then as yet, and they are not protected like these are.
  3. #53
    Nice, been looking and all i could find was expensive and not quite big enough for my 12mm. would you grab some 20mm for a loose fit over the 12mm Softy although it is a double length of 12mm so not sure that is big enough?
    20mm fits my 12mm softies easypeasy... hardly gets used these days tho, they were made for truck recovery so are waaay overkill for most 4X applications... only ever been used regularly by my young fella in a prev job he had for a coupla years.
    I made my sheaths from discards but FWIW I would suggest a metre of 20mm and a metre of 14mm and you would have a lifetime supply of sheathing for under $30.
    I just keep a few sheaths in with my softies and slide the sheath on or off a shackle as required.
  4. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    MB (13th June 2019), MudRunnerTD (8th June 2019), Winnie (8th June 2019)
  5. #54
    So just received this on the mail today. Looks pretty sweet actually. It's smaller than the other pics. This is the 5 ton unit which is a higher rating than the ARB snatch block.
    Keen to see the bigger one but this is a rippa.
    The slot is rated for up to 12mm but is a 20mm groove.
    The centre is about 30mm. Will be interested to see how the 12mm soft shackle fits through the hole.???
    The outer diameter is 80mm and the inner rolling diameter for the outer rope is 40mm.
    Thanks a heap to @10G for sorting this. Can't wait to have a play.
    MB (13th June 2019)
  7. #55
    Well done Blokes, Movers & Shakers, getting testing cool stuff done
  8. #56
    May 2016
    lower west victoria
    30 Post(s)
    I'm keen to see how you get on with it Darren. Gee it does look small. One thing I'll be interested to hear about is if it's difficult to use coz of its size?
    Things like, is it too small to handle? Does it get lost in the recovery bag? do the ropes slip off it too easily and so on.
