Results 1 to 10 of 16
Thread: Tools Reqd for Wheel Bearings
    May 2016
    lower west victoria
    30 Post(s)
    I'm putting together a set of tools for when I go away on trips.
    I have the special hub socket but what other tools would I use if I have to tighten my front wheel bearings? I've not had to do one before.
    Thanks.
    Thanks.
    Hi mate try and find @mudrnnerTD s swivel hub rebuild its bery detailed
    Allen key to remove the free wheeling hub, circlip pliers and the hub nut tool is all you need from memory.
    threedogs (3rd June 2019)
    May 2016
    lower west victoria
    30 Post(s)
    Gday TD, thanks for the help, I'll take a look.
    May 2016
    lower west victoria
    30 Post(s)
    Thanks Winnie. Are those allen key bolts very tight?
    What about gaskets etc for reassembly?
    Jun 2019
    Yep, tools as Winnie said:
    I just re did mine. This is for a GQ
    You'll need an allen key for the 6 allen head bolts.
    Get yourself a set of multi circlip pliers to remove the circlip off the end of the axle.
    To remove the inner cover, just grab it with a rag. It slides off pretty easy.
    54mm socket to remove the nuts.
    A spare lock washer wouldn't go astray, or at least a hammer to hammer it flat to reuse it. But always good to have a spare in case it's been used a few too many times.
    Torque Wrench that goes up to at least 170Nm
    Flat blade screwdriver to bend the lock washer. I actually use a bicycle tyre iron. Less chance of doing any damage when bending the washer.
  8. #7
    No gaskets required but I like to seal the free wheeling hubs with rtv sealant.
  9. #8
    May 2016
    lower west victoria
    30 Post(s)
    Thanks everyone for the help.
    Here's the thread TD referenced above:
    http://www.nissanpatrol.com.au/forum...ghlight=swivel
  10. The Following User Says Thank You to 10G For This Useful Post:
  11. #9
    334 Post(s)
    This is the best thread just for Wheel Bearing adjustment.
    http://www.nissanpatrol.com.au/forum...ing-Adjustment
    You wont need the circlip pliers just to tighten the wheel bearings. Leave it on.
  12. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    10G (4th June 2019)
  13. #10
    334 Post(s)
    Quote Originally Posted by Dingo1966 View Post
    You really only need to try and get the 170mn of torque on brand new bearings and only to bed them in for a couple of spins. you then need to back them off to basically finger tight. On the GQ Lock nut the Lock nut locks down on the bearing nut but the pressure on the Bearing nut is finger tight. The GU upgrade this is not required as the locking screws do the work of locking the rounds nuts together.
