Results 1 to 2 of 2
Thread: Boost guage in centre console install
    Apr 2019
    Kalgoorlie , WA
    Hi All,
    Just wanted to add my Boost Gauge install to the mix, didn't really want an illuminated guage in my face on the pillar, as I would just end up watching the needle all the time.
    Had to modify the hole a bit with a file to get the guage sitting straight and not not flush with the trim, this was also to clear the internal steel frame.
    Not sure what the little vent looking area was in the trim for but with mine it was wasn't being used for anything
    Gauge is just turned around so I can see the relevant section clearer, no need to see it all.
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    I would of used a single gauge pod holder and mount it upside down so you could read it as you driving, with the gauge light , just connect to your dash light dim switch. regards Alex
    Maybe something like below in link and trim it to cover the hole in dash already :-)
    https://www.ebay.com.au/itm/2-52mm-U...cAAOSwoPBdKPm~
