Results 1 to 10 of 13
Thread: Things to look for - Buying second hand GU7
    May 2019
    Kyabram
    HI All
    If this question is supposed to be in a different section - sorry but looking for some advice on things to look for when buying a Patrol.
    I've got my eyes on either an ST or Ti wagon. I've got about 4 or so to look at ranging from 100k to 180k on the clock. All 2011.
    Apart from service history, interior detail signs of wear, and looking for signs of red dirt and other matter or damage under the vehicle, what else can you suggest I look for?
    Having previously owned a 2000 D2 Td5 - which indecently (incedently ) was an awesome vehicle until its first major creek crossing..., how do the electrics hold up in the Ti? Has anyone had any dramas? Trying to weigh up whether the luxury is worth it or is the Ti basically a Toorak Tractor exclusively.
    Any information/advice would be great.
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Looking for any specific engine? I've got a gu3 td42 ST (similar running gear) with 260k km on it and Its never had any issues I didn't cause. There might be some specific things to look for depending on what engine you pick but otherwise you've pretty well covered it I think.
    Actually I did a front wheel bearing not long after i brought it but that wasn't a big deal. I think you'll be fine in a ti unless you properly drown it.. but that'd probably give you grief in whatever model.
  3. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
    gavcan01 (10th May 2019)
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Quote Originally Posted by gavcan01 View Post
    Having previously owned a 2000 D2 Td5 - which indecently was ......................
    Must agree with you there Gav. When describing Discos - indecent is the word.
    May 2019
    Kyabram
    Haha yeah oops. Incidentally was good before the water then the 3 amigos came and went often. Then I guess became indecent. 😉
    May 2019
    Kyabram
    The ones I’m looking at all have the crd 3l
    Jul 2010
    Thurgoona
    7 Post(s)
    It's like buying any second hand vehicle, you should give it a really good check and try and find out who owned it and what they did with it. A good service record is a bonus and a check via RACV (although at a cost) can save you lots of dollars down the track.
    ZD30 engines are a bit fragile if not treated well so I would at least make sure I had a mechanic that knows Patrols have a look for cracked heads and holes in pistons. The rest of a Patrol is usually very tough and reliable - but any car can have a problem.
  8. The Following User Says Thank You to BillsGU For This Useful Post:
    84 Post(s)
    Check the rear spring towers. They have a tendency to stretch and crack at the welds on the chassis. Towing heavy loads over rough roads can cause the problem. There are kits available to rectify it.
  10. The Following User Says Thank You to mudnut For This Useful Post:
    gavcan01 (14th May 2019)
  11. #8
    May 2019
    My GU7.
    What I'd check after owning mine 6 years.
    * belt tensioner
    * front alternator bearing
    * front timing case leak
    * take intercooler hose off and look for excessive oil.
    * oil anywhere on crimped ends of intercooler
    *Air bag recall
    *Throttle position sensor recall replaced
    * solid service history.
    * Rear door droop.
    *CRD side very hard to check. Get someone to drive behind as you accelerate, and drive a few, only needs to be a short distance test drive to get a feel of what's average power etc.
  12. The Following User Says Thank You to Blitter2019 For This Useful Post:
  13. #9
    May 2019
    Kyabram
    Quote Originally Posted by Blitter2019 View Post
    My GU7.
    * belt tensioner
    *Air bag recall
    * Rear door droop.
    Haven't looked at any yet but if there is oil around the intercooler is that a sign to stay away or simply replace?
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Just time to replace the Intercooler, it's a common issue as they are crimped not welded. Heaps of info in threads on here on how to replace.
    Jack
    2024 Isuzu MUX
