Page 163 of 187 FirstFirst ... 161162163164165 ... LastLast
Results 1,621 to 1,630 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #1621
    Getting bloody close now.
    Many little jobs finished. Fitted the grille. Parker lights. Filled the winch with oil.
    Trying to adjust the bonnet and snapped a bolt damn it so the bonney had to cone off!
    Took the opportunity to run the washers back in and fit some LED Lighting.
    Winch grill switched in and labeled
    Re fitted the airline to the rear winch with a new fitting and the airlocker works again!!!! Yippee!!!
    Just for interest this is the part i needed. Before buying online i did a price check at ARB......... $12 in stock. Identical.
    Tidied up the winch 24v wiring and added some extra insulation
    Fitted 2 Air Vessels for extra storage.
    Swapped to a pin for the winch dildo
    And modded my winch hook to be a quick release for my new 12mm rope
    Then made 2 fid in 12mm to use to work with my 12mm rope. Going to make a couple of soft shackles and splice in my loops
    12mm FTW!!!
  2. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (31st March 2019), PeeBee (31st March 2019)
  3. #1622
    Looks good Darren, What make and specs are on the air compressor?
  4. #1623
    In case you were wondering. A 12mm soft shackle is Massive!!
    That used 100inches of 12mm rope. Made one with 60inches and could not complete it was too small.
  6. #1624
    Hi Phil. I have a 3/4hp Big Boss. Early model. At the time it was the bomb, when it dies i will buy a double arb job
  7. #1625
    Thanks for that. I am looking to upgrade my old ARB diff lock compressor - had it since 1997, so its served its time, still pumps OK. If I cant sort out the endless air unit when I tear the front of the engine down I think I will go a big one - will have to look at the ARB twin also.
  8. #1626
    I bought a couple of 11mm units a while ago, not small either. I will say however that I am still sitting on the fence regards using them instead of a metal shackle for winch pulls - impact or energy situations like snatch stuff, yes, won't hesitate, but need some more assurance I think - the 'knot' bit is what has me cautious.
  9. #1627
    So i watched a heap of youtube threads on these before i began. This design is a stronger design than normal. It is rated at 220% strength of the 12mm rope. Well strong enough.
  10. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (9th April 2019)
  11. #1628
    Your nut looks larger than mine, but thats hardly surprising is it!!!!! I don't doubt the mechanical strength, its just my engineering mind getting stuck with shackles as we use them every day and no soft shackles are rated for lifts - again, just a mind block. Right bit of gear for the job in some circumstances I guess.
  12. #1629
    Yeah this design is an improved design with the ends buried into the Nut making it significantly bigger but it it impossible to now invert the Nut which is a weakness. No tails
  13. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  14. #1630
    Jeez its coming along really nice now Darren. Whats that big post thingo you go hanging off the front of the bar for?
