Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 88
Thread: Going Solar on the GU wagon
  1. #71
    22 Post(s)
    Quote Originally Posted by altech View Post
    Hi Guys, the Big and bloody heavy battery arrived today, hmmm did I mention heavy lol. Did some improvements / upgrades to the battery wiring. Now waiting on the real MPPT charger to arrive. keep you posted regards Alex
    Attachment 78214
    Attachment 78215
    I have a few Questions.
    How did you crimp the larger cables?
    What the go with that figure 8 cable to the the Negative and what size is the main negative?
    96 GQ coil/Cab
    08 G6eT
  2. #72
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    1/ Soldered in like you would a Anderson plug. 2/ 8 gauge wire is neg and it's connected to second battery from that to my rear electric cargo barrier frame work which is grounded to the body of car.
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
  3. #73
    22 Post(s)
    Ah ok. That's why it doesn't look like they are crimped
    96 GQ coil/Cab
    08 G6eT
  4. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    altech (26th March 2019)
  5. #74
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Guys, Installed my Real MPPT controller today and works great, it does have a add on Bluetooth receiver that connect's to my phone. in the pic I have changed the wiring again lol regards Alex
  6. #75
    Nov 2011
    Rupanyup, 3388, VIC
    And Yes I have MT50 receiver too.
  7. The Following User Says Thank You to altech For This Useful Post:
    Yeti's Beast (6th April 2019)
  8. #76
    Wow the Cargo Barrier is pretty kool mate. What glass did you use? Assume it is profiled right? Well done mate. Fair effort indeed.
    Can you post a pic zoomed out a little so we can see it up and down and maybe half up?
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    altech (6th April 2019)
  10. #77
    You have got to fix that though mate, thats junk. You can do much better than that bud. Just say'n
  11. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  12. #78
    Nov 2011
    Rupanyup, 3388, VIC
    Not Glass, but 10mm plastic . went to dealer, he had a off cut $50 bucks, then I cut it to size
  13. The Following User Says Thank You to altech For This Useful Post:
    MudRunnerTD (6th April 2019)
  14. #79
    Nov 2011
    Rupanyup, 3388, VIC
    Yes did see this after the photo was taken, cheers Alex
  15. The Following User Says Thank You to altech For This Useful Post:
    MudRunnerTD (7th April 2019)
  16. #80
    im sure i have seen the equivalent on your beast? come on mate, not everyone is perfect
  17. The Following 2 Users Say Thank You to rusty_nail For This Useful Post:
    altech (7th April 2019), MudRunnerTD (6th April 2019)
