Results 11 to 20 of 33
Thread: To chip or not to chip...
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    @mudski
    That's true Mark, but the OP is planning long term travel, & will be in a position to take his time.
    Time will not be a concern, fortunate in that.
    I guess it is my memory of being impatient behind a slow towing vehicle in my past and wanting to avoid being that person
    We have done a couple of short excursions and haven't encountered any real issues apart from dropping to 85 / 90 on some hills.
    I remember from your blog the statement that it took some time for you to stop thinking you had to 'get' to the next stop. Maybe I just need a mindset change.
  2. #12
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    @Mc4by
    For your consideration. My eng CRD, I have done progressive eng mods over time - NADS, cooler, intake induction, remaps, high flow turbo (run max B 26psi (rear wheels 136kW/512N-m) have ended up with a good result but fair few $$ spent to get there and lessons learnt. ECO from home (@600m) up to the snowy mtns (1300m), total 450kms: stock 14.5l/100kms and now easy 12 l/100kms - veh 3.5T
    Chip / Remap / or leave as is, up to you. What you have done to date is good.
    Irrespective of what you do longer term, IMO, these ZD30 engines do need to breath well, suggest you look at doing an upgrade to your air intake (induction) first and this may satisfy your need. As stock, the induction is too restrictive and would be even more so if you go with Chip or remap and run at higher boost. This alone will provide improved performance pwr/torque/EGTs. Too much restriction before turbo causes a vacuum and the turbo works harder to overcome this. Solution depends on what you are prepared to spend and it helps if you able to do the work. Possible Option: Use current snorkel with an upgraded airbox and 3" pipe from airbox to turbo with 2.5" flange elbow to turbo compressor housing(easy bolt on).
    This option sounds easy, relatively cheap and diy so that could be the path I choose.
    After that I can see if I really need to do more.
  3. #13
    176 Post(s)
    Quote Originally Posted by Mc4by View Post
    It has been uncommon for us to have held others up. Traffic density is generally low except when in towns/cities, & then we are perfectly able to manage the traffic speed. On the rare occasion on slow & steep twisty roads where no overtaking lanes existed we have simply pulled over as soon as safe to let someone behind us get past. Most give a hoot or a wave of thanks. In areas where roadtrains are common I usually call them on channel 40 & ask if they would like me to pull over. 99% of the time the response is along the lines "Nah mate, just carry on as you are, & I'll come around you on the straight in X kilometres. I'll let you know when". When they are pulling past I just back off to help them pass quicker. Always get thanked & often end up having a bit of a conversation to boot. If you can manage 85/90 on hills I can't see a problem.
  4. The Following User Says Thank You to Cuppa For This Useful Post:
    Mc4by (22nd March 2019)
  5. #14
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    Improved induction is really what need to do first anyway and will compliment what you have now.
    What cooler are you running and how are you controlling spool(eg: needle, VNT sol or max spool.)?
  6. #15
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Standard cooler, airbox etc aside from the snorkel and 3 inch exhaust. Spool control via needle.
  7. #16
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    @Mc4by
    Is this the sort of thing you are talking about?
    https://gcg.com.au/diesel-performanc...box-lid-detail
  8. #17
    FWIW my opinion is that it is almost pointless fooling with the induction on a factory turbo, larger turbo hell yeah, factory not so much.
    You'll see much better improvement from more efficient inter-cooling to give you denser air (more oxygen) into the intake unless you crank the boost a fair bit higher than factory.
    Most people are reluctant to do so and the CRD seems to handle it more than the Di's but either way the factory turbo typically gets enough air thru the factory plumbing.
  9. The Following User Says Thank You to the evil twin For This Useful Post:
  10. #18
    Jul 2017
    40 Post(s)
    Agree with @the evil twin of benifits of installing an upgraded IC.
    IMO the stock air box is very restrictive / limited, resulting from the way that the inlet is perpendicular to the filter element and provides very little clearance to the filter cylindrical face. This design causes turbulence and poor flow.. Have a look at the crap that builds up at against filter face at this concentrated point (room for improvement).
    I suggest looking at this 9" pod A/B takes a K&N pod filter(KNRE-0870). The airbox made by a boiler maker Ben Lipscombe(thru ZD warriors_ FB), draws very well. $340 (box only)+postage. Two lengths available 300mm(ZD) and 330mm(TD42). I fitted the TD42 box and had to mod to the radiator plastic shroud-15mm cut away(easy done), with body saw, to bring it closer to radiator. This provided 330mm long A/B provided 50-60mm clearance from inlet end face to base of pod filter. Need to buy K&N pod filter: KNRE-0870. Say $450 total.
    Ben can supply either 3 or 4" for inlet / outlet. Suggest 3" inlet then no need to mod hole in inner guard and 4" outlet and use 4 - 3" 90 deg silicon bend.
    I connected box up to turbo with Fabwitz Industries 3" pipe(MAF sensor port / CC (PCV)return fitting and vac pick up fitting in pipe). You can make up your own similar to pic attached, using existing stock MAF port duct section.
    Fabwitz Industries thru FB (not cheap but good quality). Fabwitz does air boxes as well and there are other available.
    Read other forums (Google about and see what is being done). Prepared to provide more info mate.
  11. #19
    I have a 2002 GU III ZD30DI.
    I would like opinions on chipping or not chipping this motor.
    I will be towing a light weight camper trailer over a long distance but also over a long time.
    One workshop said yes, it will be great; another said, No, on that motor it will adjust fuel but not air and that will be bad.
    Has / does anyone run this motor with a chip and what do you think?
    As a base line I have full NADS, 3 inch exhaust and the truck runs well.
    Some hills cause me minor grief and that is what I want to eliminate.
    TIA
    My 2004 3ltr full nads runs a DP chip, first I set it on 10 but it just blew black smoke.
    I have it on 5 now and is great I can keep up and sometimes beat the newer 4x4s.
    tows my camper to the Murray with no problems at all,, you have to remember its only a 3ltr in a big 4x4 so
    you wont be entering any grand prix soon, Agree with the up grade IC 30% bigger i even run the taller scoop
  12. The Following User Says Thank You to threedogs For This Useful Post:
    Mc4by (23rd March 2019)
  13. #20
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    I shall banish myself to the archives to see what has gone before me with regards to upgraded turbo's, intercoolers and induction systems.
    I am not desperate to do this but if it is affordable and makes overall effect better I may dive into it.
