Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Spot Light Wiring to Front of Roof Rack
    Feb 2019
    Victoria
    Ran the wires up the D pillar terminating in a 50 amp anderson plug,
    easy if I need to replace the light bar,, works a treat
    Would you happen to have a photo of where exactly you mounted the Anderson plug?
    Sent from my CPH1701 using Tapatalk
  2. #12
    Quote Originally Posted by Rixter View Post
    I have a chinese ARB copy roof rack and just bolted
    the Anderson plug to the roofrack mounting plate
  3. The Following User Says Thank You to threedogs For This Useful Post:
    Rixter (19th March 2019)
  4. #13
  6. #14
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    I did mine like this but didn't even bother cutting the notch out. Just clamped the seal over the top. Always intended on finding a better way but I've never had an issue in the 4 or so years it's been like that.
  7. The Following User Says Thank You to 0-TJ-0 For This Useful Post:
