Results 1 to 4 of 4
Thread: ZD30 DI 2000 excessive blowby, performance 100%, no smoke, popped out injector seal
    Hi all
    I have had ZD30's for many years now and know a lot of their quirks and probs .. However after some advice on how to start on this.. This car has been used by us for the last 10 years and had a turbo replaced 3 years 80,000k ago has 244,000 on clock.
    The good
    No Smoke
    No nasty noises
    Engine is running as good as always (One of the nicest running ZD30's we have have)
    Turbo spooling fine
    No water use
    Starts immediately
    The bad
    Popped out a injector seal and oil came out everywhere
    I washed it down, pushed the seal back in with the help of a couple of spanners for leverage .. it went back in easy as and did not leak surprisingly however there is a lot of pressure coming out of the oil filler when engine running and cap off..
    Thoughts please ....
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Piston ring wear - cracked head - cracked piston. None of them a cheap or easy fix.
  3. The Following User Says Thank You to BillsGU For This Useful Post:
    PatrolMark1 (31st March 2019)
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    I saw this happen on a pathfinder... 2.5L I think, ended up being a complete rebuild. bore was tapered and a new head,
    sunshinecoast
    3 Post(s)
    unless you have seen it before many people are suprised by the amount of blowby coming out of a diesel . might be a good idea to check a couple of other motors to see how yours compares. also it's best to check when engine is warm as rings dont seal as well when cold.
