Page 126 of 136 FirstFirst ... 124125126127128 ... LastLast
Results 1,251 to 1,260 of 1356
Thread: All Things Chev
  1. #1251
    198 Post(s)
    OK, waiting to pay the invoice from Leroy Diesel for the DS-2 set. $275 USD plus $40USD delivery
    Ordered, now just waiting for its delivery, will go on at the same time as the timing gears and fluid damper
  2. #1252
    198 Post(s)
    Finally got the part number for the high output water pump from BD. Its an AC Delco 251603. It appears to be the same capacity as the original high output pump, but has a screw on fan assy instead of a bolt on. Its serpentine belt driven also.
  3. #1253
    198 Post(s)
    Ordered the fluid damper this morning. Ended up going with Leroy Diesels instead of Summit. Summit made a meal of the enquiry and their arrogance lost them the sale. Could not get a delivery cost out of them, their auto check-out system contradicted the sales guys and then I had to resubmit a product enquiry after sending them a request to delete the original - NOPE, why should I have to do the work to fix your screw-up. Pack of monkeys.
    One email to Leroy Diesel, invoice received, paid 5 minutes later, 15 minutes later had tracking number, now thats service.
  4. #1254
    198 Post(s)
    These were waiting for me when I got home for R&R today, timing gear set and fluid damper. Heading over to the land of Yarra Glen on Monday to pick up my safely stored Supercharger kit from Mr @MB and @AB - thanks guys. Its real when the bits are in your hands - now just have to find the time to sort it out.SANY0080.JPGSANY0082.JPGSANY0080.JPGSANY0082.JPG
  5. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (29th March 2019)
  6. #1255
    Most welcome mate and welcome back home!
    It is most definitely safely stored, on top of my now 6.5SC
  7. The Following User Says Thank You to MB For This Useful Post:
    PeeBee (30th March 2019)
  8. #1256
    198 Post(s)
    Thats fine, you will probably get more use out of it in the next couple of years than I will
  9. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (30th March 2019)
  10. #1257
    198 Post(s)
    Getting real now, whole kit in my hands.SANY0083.JPGSANY0084.JPGSANY0085.JPGSANY0086.JPGSANY0088.JPG
    The photo of the front of the engine is from the trial fit due to wider pulleys being installed
  11. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (1st April 2019)
  12. #1258
    198 Post(s)
    Guys, radiator was ordered with bungs for upper and lower temp sensors plus a redarc low coolant sensor. True to form, the Redarc bung was not added. Can you advise how far down from the top of the radiator it should sensibly sit - will have to get this welded in before I start.SANY0089.JPG
    MB (14th April 2019)
  14. #1259
    198 Post(s)
    Dare I make the reckless statement that I have finished buying stuff for the s/c conversion???? Just pulled the trigger on a billet aluminium harmonic balancer pulley in 8 rib config from Leroy diesels. $250USD plus freight of $75USD. This will replace the unit I had supplied by BD which is a heavy steel and rubber unit - prone to delamination over time, and will reduce weight by 3kg approx.
  15. The Following User Says Thank You to PeeBee For This Useful Post:
  16. #1260
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    Nope, don't say it.
    Soon as you do something breaks, doesn't fit or dissapears under the fridge..
  17. The Following 2 Users Say Thank You to 0-TJ-0 For This Useful Post:
    MB (14th April 2019), PeeBee (15th April 2019)
