Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 88
Thread: Going Solar on the GU wagon
  1. #41
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Ok Guys, the rack system in place, this solar panel not going anyway regards Alex p.s. And Yes I made it myself,
  2. The Following User Says Thank You to altech For This Useful Post:
    mudski (21st December 2018)
  3. #42
    Nov 2011
    Rupanyup, 3388, VIC
    Ok Guys, check battery this afternoon and is showing 13.7 because I set on the controller hours only at 2 hours per day, So I think I'm happy with that, not 14.4 as it was showing yesterday regards Alex
  4. #43
    Expert Yeti's Beast's Avatar
    Aug 2016
    Jimboomba
    4 Post(s)
    I was thinking of making one of these before I sold the Patrol
    May still make one for the new ute
    Proud BTrol Owner
  5. The Following User Says Thank You to Yeti's Beast For This Useful Post:
    GQtdauto (20th December 2018)
  6. #44
    Nov 2011
    Rupanyup, 3388, VIC
    Quote Originally Posted by Yeti's Beast View Post
    Proud BTrol Owner
    Looks good , whats that 2 panels of 200watt each regards Alex
  7. #45
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Guys, just upgraded from a PWM to MPPT solar controller as this will be better for my needs and finally fitted my second battery that located in my draw unit and now have the dc to dc controller runing to charge the second battery. all seem to be working great. oh happy days of free energy from the Sun, :-)
  8. #46
    Aug 2016
    Jimboomba
    4 Post(s)
    I hope you have been keeping that battery charged because more than likely it’s stuffed. See the competition sticker in the front !
    That ended June 2016
    Proud BTrol Owner
  9. #47
    Aug 2016
    Jimboomba
    4 Post(s)
    Quote Originally Posted by altech View Post
    No, they were 12v 180 watt
    Proud BTrol Owner
  10. #48
    Nov 2011
    Rupanyup, 3388, VIC
    Proud BTrol Owner
    all good on the second battery 13.4 V
  11. #49
    Is that a wet cell battery? inside the cabin? Not a great idea. I had a calcium wet cell crap out and it filled the cabin with fumes and that means corrosion - yet to get a handle on the potential of what slow creeping damage I have to the electronics inside the car. Cleaned out @MudRunnerTD sinus's!!!!
  12. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MudRunnerTD (19th March 2019), Yeti's Beast (19th March 2019)
  13. #50
    334 Post(s)
    Hi mate, good effort sorting all that out. I dont want to rain on your parade at all mate but a couple of comments for your consideration though. I think the cables coming off your Projector150 are very small and not big enough for a dual battery system beyond a trickle charge and i'd consider swapping them for something bigger. Also i note you have used domestic 240v 3core flex for your wiring. I have used this in a previous build thinking it was the go but it lacks flexibility and goes hard over time. It doesnt like vibration and lack efficient current flow on 12v. a fine multi strand will be far more flexible and provide much more efficient 12v Current flow. I would avoid using 240v anything on your car. It will probably get you years of service but maybe not.
  14. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    PeeBee (19th March 2019), Yeti's Beast (19th March 2019)
