Hi All,
I have a 2001 GU Patrol 3ltr turbo DI auto. The pin dropped out at 270,000 ks, replaced engine in January this year new head and fuel package, radiator 12 months old, new alternator. Hooked up the caravan in June for 3 month trip, found going ok on the flat but any climbing it would loose power, had it dyno tuned in Townsville but little or no improvement.
On arriving home thinking it could be a transmission problem I took it to my guy to check out he could not find any problems so suggested it was an engine fault. Booked it into diesel engine specialist in Dandenong found leaking IC so replaced it, new MAF sensor and other bits, after further testing they advised that the turbo was ceasing so replaced that apparently all was ok. No problems cruising around home so last Friday hooked up the caravan for our next big trip and off we go, once again no problems cruising on the flat but when the climb starts the power drops off, some of the big climbs we were lucky to make it to the top also temperature was peaking. Did 300 ks then headed home. Truck is booked in to Dandenong for next Monday, my trouble is I have spent shed loads of money apparently for nothing (apart from the IC).
I have not fitted N.A.D.S. for fear of loosing engine warranty but have installed a Provent catch can.
Any thoughts or ideas to what's causing my problem would be much appreciated as it is doing my head in.
Thanks,
Barry
