Page 50 of 64 FirstFirst ... 4849505152 ... LastLast
Results 491 to 500 of 635
Thread: Rosscos GQ Rejuvenation
  1. #491
    Good outcome Rossco, did they resolve the fuel tank leak or have you sorted that out?
    Yeah they fixed that was the sender. Filled it up again and all good.
    Thats a great result mate. What did they have tonsay about it? Where they familiar with the BW? Is that comparison run your run on day one using the other pump? That is nearlly embarassing if thats the best old mate could get from his own pump!!!
    Interesting. We should have a chat mate
    Yep comparison was from drive in on old pump, thought it was putting out a little more than that actually. If it weren't for issues i would have been more than happy with it, once it was up & running was absolutely great but down low hopeless and starting issues. Many occasions pulled out into a small gap in traffic and would feel like it was stopped dead then would go once built up a bit of speed, which is not ideal lol.
    Think they were pretty impressed, said it was one of the highest powered TDs they'd done, not sure they had much to do with BWs on TDs before. Certainly credit to the Queensland boys and AB for such awesome R&D pretty easy for us to reap the benefits now lol. Been very happy with Cornells too pretty impressive set up over there, clean as a whistle place. .
  2. The Following 5 Users Say Thank You to Rossco For This Useful Post:
    Hodge (28th November 2018), MudRunnerTD (28th November 2018), mudski (16th December 2018), PeeBee (28th November 2018), Winnie (28th November 2018)
  3. #492
    Yeah they fixed that was the sender. Filled it up again and all good. Yep comparison was from drive in on old pump, thought it was putting out a little more than that actually. If it weren't for issues i would have been more than happy with it, once it was up & running was absolutely great but down low hopeless and starting issues. Many occasions pulled out into a small gap in traffic and would feel like it was stopped dead then would go once built up a bit of speed, which is not ideal lol.
    Yeah you look like you get a fair bit more earlier than i do actually. I will take a pic of mine and post it here to compare
  4. #493
  5. #494
    See above
  6. #495
    Yeah wow. If those speeds are correct then regardless of the tacho your peaking at 75 to 80kms/h and im just winding up to peak at 90! That is nearly a gear!! Wow
    At 70kmh im producing about 100kw and you have 140kw already.
    At 80kmh your on boil at 165kw and im just thinking about it at 140kw! I dont see 165kw to about 105kmh. Jesus! Thats a big difference.
  7. #496
    Thats got my attention mate. Kinda lagging a little by comparison. And 120 extra newton metres.
  8. #497
    What size tyres and diff ratios are you running mate?
  9. #498
    Rosscos on 35" and 4.6's mate.
  10. The Following User Says Thank You to AB For This Useful Post:
  11. #499
    Hmmm ok so the 35 will suck a little and the 4.6s will make a fair bit of difference id think to that power curve?
  12. #500
    Absolutely but its both and give and take. would probably equate to 31-33" on 4.3's maybe?
  13. The Following User Says Thank You to AB For This Useful Post:
