Page 52 of 64 FirstFirst ... 5051525354 ... LastLast
Results 511 to 520 of 634
Thread: Turbo Upgrades for the GUIV TD42Ti
  1. #511
    Yeah, this is how I read it first (blue current tune with reduced AFR/richer mix).
    My understanding: lower the AFR is richer the mix (more fuel)) means smoke and engine heat. Not enough fuel (a high AFR) means clean running and lower engine temperatures.
    Shit I actually got that wrong, blue is pre tune and black is post tune. So your theory is correct.
  2. #512
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    OK, ring Andy and ask which trace is current. I do think it is blue. More fuel does not necessarily mean more smoke under load, is also depends on overall tune.
    If you look at your blue trace eng produces more kW / N-m and a reduced AFR (increased fuel) and fairly level. Love the result only if my CRD could a achieve this torque behavior.
    Same trend (blue trace) in both your graph and Mark's tune result. Different outputs but same trend.
    By the way rule of thumb:
    It is best said that a diesel begins to smoke when the AFR gets below 15-14:1 for a non-turbo and 16-15:1 for a turbo-diesel.
  3. #513
    The black line on my chart is 100% the after tune.
  4. #514
    Jul 2017
    40 Post(s)
    OK then so, AFR higher and leaner.
  5. #515
    Jun 2018
    25 Post(s)
    Yep, you can see there is a key with a black dot on the left for 'after adjustments' and a blue dot below for 'compare run: drive in'
  6. The Following 3 Users Say Thank You to Cremulator For This Useful Post:
    Bidja (19th November 2018), MudRunnerTD (19th November 2018), Rossco (19th November 2018)
  7. #516
    477 Post(s)
    Yeah I went in at 180rwkw and came out at 160. Less power but it runs good and no more puffing billy. I wont be changing out the turbo anytime soon. I'm done with it. Just pouring money into this thing lately and continuously chasing my tail with the cooling system. When the funds allow, I will be getting rid of the GU and buying something else.
  8. #517
    Jul 2017
    40 Post(s)
    Driveability is what counts.
    Guess he decided to run a bit leaner for eng reliability. Yes, a rich mix apart from causing emission issues, can make eng run hotter and be to the detriment of engine longer life.
    Have read that after market turbo diesel run best around 19-20 AFR or higher under full load and a factory turbocharged diesel of about 20-22:1 or higher under load. Not to say that you cannot run a richer mix many do.
    My CRD procharge stage 3 h/f turbo, runs Max boost 26psi and 19:1 AFR. Came down to 19:1 AFR from 21:1 for more fuel low down to achieve improved early boost (getting there now the need to further improve induction).
  9. #518
    477 Post(s)
    I told Andy at Diesel tec to back it off, as i wanted driveability pretty much. Engine was still running hot though after the tune. But a crap load less smoke. I haven't had the chance to take it for a good run yet to see the real benefits of the new tune and all the new work I have done tot he cooling system.
  10. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Bidja (20th November 2018), Rossco (20th November 2018)
  11. #519
    What sort of temps you seeing and under what conditions?
  12. #520
    477 Post(s)
    Just normal road driving Rossco its around 10c higher than usual. There a long'ish uphill run On the Research-Warrandyte rd mate heading north bound and not even flogging it it will see 95c without an issue on a 15c day. Any sort of load and the temps get up there real quick. Its never been like this. On the up side. The better fan and the oiled up hub does get the temps down a bit faster. I need to get it on the highway and see how it fares now.
