Page 867 of 1057 FirstFirst ... 865866867868869 ... LastLast
Results 8,661 to 8,670 of 10564
  1. #8661
    476 Post(s)
    Swapped a flasher relay to LED compatible one. Indicators clicking as they should now.
    Also attempted to fit radius arm spacers , to push the front axle forward to clear the mud flaps.
    Chassis on stands , jack under diff...
    And then realised I don't have a deep enough 24mm ... ugh.
    So I called it a day. Lol
    I have a 24mm Ring/ Open ender I used for mine here your welcome too mate.
  2. #8662
    176 Post(s)
    I do own one of them. But they're useless as the opening from under or the side don't allow much room to manourve the spanner.
    Needs a deep socket with an extension and ratchet from the rear opening.
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    Throw up a couple of pics mate. Be good
  4. #8664
    Jan 2017
    Fitted water meth kit by Snow proformance. fingers crossed
  5. The Following User Says Thank You to NZ42 For This Useful Post:
    MB (25th October 2018)
  6. #8665
    198 Post(s)
    Quote Originally Posted by NZ42 View Post
    What motor and kit are you matching?
  7. #8666
    476 Post(s)
    Wasn’t today but Sunday. I had to replace the reverse camera on the small barn door. So while I was at it I made up a new plastic seal thingo for the door, sikaflexed up any holes in the door to try and stop the exhaust leaking into the cab. Didn’t work though. I also removed the inner door handle.
    Now to find where this exhaust leak is... I have to drive with the air on recirculate all the time otherwise when I stop moving I get a nose full of exhaust fumes.
    Sent from my crapPhone using Tapatalk
  8. #8667
    198 Post(s)
    Does the GU have vents in the rear quarter panel/outer skin like the GQ? This is where I find a bit of dust entering my vehicle. Might be a spot where exhaust is recirculating?
  9. #8668
    476 Post(s)
    Yeah they do. I'll tape them up and see if it makes a difference. I'm also going to change the direction of the exhaust tip so it comes out just behind the mudflap.
    PeeBee (30th October 2018)
  11. #8669
    198 Post(s)
    I also notice your door seal is hanging down, maybe another entry point?
  12. #8670
    476 Post(s)
    Thats how its shaped to the door. Just looks like its hanging off. All new seals on every door maybe 2 years ago.
