Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: servicing king pin bearings re-grease or only replace
    Sep 2018
    queensland
    3 Post(s)
    thanks everyone next chance i get ill pull each kingpin plate out one at a time and clean them off and use one of these needles to re-grease them.
    will the bearing need to go back in at the same spot? meaning is i pull the plate out and the bearing gets spun 90-180 degrees and put back in would that be bad?
    im thinking if this happened the bearing would be contacting a new area on the race.
  2. #12
    334 Post(s)
    Quote Originally Posted by Fireblade View Post
    Just remove teh cap and leave the bearing on teh cap. You wont need to use a needle packer for the king pin bearings. If you ahve ever repacked a bearing using your hand then use that technique, will work perfectly. Just make sure the king pins go back where they came from, if your doing them one at a time you cant get it wrong.
    that needle grease packer will really only become handy for the pressed in rear wheel bearings as you can only get to the face of the bearings.
