Page 859 of 1057 FirstFirst ... 857858859860861 ... LastLast
Results 8,581 to 8,590 of 10564
  1. #8581
    Yep. And for future reference cruiser trays are narrower.
    There's just no stance in a cruiser.
    Gong him Red!!
  2. The Following User Says Thank You to Plasnart For This Useful Post:
    katwoman (12th September 2018)
  3. #8582
    Nov 2010
    Getting a life...
    38 Post(s)
    Got the canopy finished and loaded. Now to see how the N/A likes the extra weight.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  4. #8583
    Got any pics?
    Gong him Red!!
  5. #8584
    Sep 2018
    queensland
    Remove all the old inline use holders and went with an ebay eBay box for $20
    Led lights come on to show if a fuse is blown. Much cleaner, I’m so happy.
    I also trimmed the factory fuse box lid as it was a pain to remove, it kept catching on the factory harness. Can’t even tell it’s cut but it’s so easy to remove and refit now.
  6. The Following 3 Users Say Thank You to Fireblade For This Useful Post:
    Clunk (15th September 2018), Cradoka (12th January 2019), GQtdauto (15th September 2018)
  7. #8585
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Installed the Boss Coil Tower Brace Kit, piece of cake installation. Less than an hour to do the lot, coil spring compressor and no need to undo shocks or sway bar.
    Just about took me longer to raise the car and remove and refit wheels. Nice bit of kit.
    Jack
    2024 Isuzu MUX
  8. #8586
    177 Post(s)
    You're a better man than me Jack. How'dya go with those bolts nuts fiddling on top next to fuel lines... I invented new swear words doing those.
    Ballarat Area
    26 Post(s)
    Actually had no issues, cleaned it up and put silicone on the top plate of the brace then loosely bolted in place using the bump stop bolts. Had room to place the nuts on top, started the thread and hit it with an 18v impact driver (also used loctite). Then redid the bump stops, I will check the fuel lines to make sure they aren’t touching.
    Jack
    2024 Isuzu MUX
  10. The Following User Says Thank You to jack For This Useful Post:
    Hodge (16th September 2018)
  11. #8588
    Sep 2018
    queensland
    Fitted front brake pads, gu has 190,000km and the pads where genuine Nissan in it couldn’t be the factory pads after that many km surely?
    I used bendix pads same as the rears now, I’ve never had an issue with em so stick with what I know.
  12. The Following User Says Thank You to Fireblade For This Useful Post:
    mudski (16th September 2018)
  13. #8589
    Mar 2018
    Finally got around to installing my second auxiliary battery today, for a total of 270AH.
    Nothing like a couple of cold beers while up the bush, and no fear of running the batteries down too low.
  14. The Following 3 Users Say Thank You to sly13 For This Useful Post:
    GQtdauto (18th September 2018), mudski (16th September 2018), PeeBee (16th September 2018)
  15. #8590
    84 Post(s)
    2"lift is out and brand new rear shocks have been fitted with the standard springs. The vehicle sits as solid as a rock on the road and the ride is smooth.
  16. The Following User Says Thank You to mudnut For This Useful Post:
    PeeBee (18th September 2018)
