Results 1 to 10 of 14
Thread: Scan tools
    Aug 2018
    Scan tools
    Hey guys new to the forums.
    I own a 3L DI gu patrol and having some issues with it running. I have used a foxwell NT200 and also a Actron CP9576 but they dont seem to work on my 3l DI. Does anyone know a good scan tool to use or to buy that can actually work on a DI? Cheers, this is my rig atm 39467585_275708943247578_4118958973569204224_n.jpg
    Dunno if 4x4 SC still sell one, but theirs works on a Di.
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    Mark, was this the EDS tool from Berrima Diesel _ OBD11 compliant?
    Jul 2017
    40 Post(s)
    Quote Originally Posted by Craig Mc View Post
    Craig, the ECU Talk scan tool is widely used for non-CRD ZD30DDTi. Check the diesel compatibility list on the attached link. It also explain the configuration of the Nissan Consult protocol (14 pin connector) pre CRD.
    http://www.ecutalk.com.au/diesel.aspx
    These have USB interface also.
  5. #5
    Ahh yes it was too. ECUtalk as you mentioned is the correct tool for the earlier Di's.
  6. #6
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    I have a Nissan Consult for pre 2000 Patrols together with ECU Talk Software.
    See Screen Shots here http://www.ecutalk.com.au/screenshots.aspx
    Free to good home.
    Pick up in Pakenham
  7. The Following User Says Thank You to Bob For This Useful Post:
    Bidja (20th August 2018)
    Jul 2018
    Hi Bob, would this work with a 2000 GU with a 4.8 petrol eng? Mine is surging and flat spotting just off idle & is intermittent & would like to do live data. Thanks - Leigh
    Oct 2010
    Pakenham
    47 Post(s)
    Quote Originally Posted by LeighC View Post
    @LeighC
    Yes I believe it will.
    If you want to bring it around it will take 5 minutes to hook it up to test
    Regards
    Bob
  10. #9
    Jul 2018
    Thanks Bob,
    I have been told I need Consult II, I have an OBD2 plug under the dash but it doesn't appear to talk the later language.
    Its a bit hard to bring it around as I am in Northern Vic above Shepparton, I do know a guy who lives in Dandenong that I may able to get him to pick it up, is that close to you?
    If it doesn't work he could drop it back, he drives a car carrier & comes up regularly. I could send you a prepaid postage bag would that be OK?
    I would like to get to the bottom of it really because my next step is a new TPS & that is expensive for an auto trans. as you have to buy the whole throttle body with motors & so forth, the vehicle has done 300K so it could be getting worn in the resistive pots. I do not have a check engine light on & the Nissan dealer cant find anything, have fitted a new MAF sensor & 2 oxy sensors, done the valve shims, set the timing, done the 3 throttle relearns & still has this intermittent lean mixture just off idle & it even mucks the auto changes up when it happens, other than that it drives perfect 90% of the time.
    Cheers for your help- Leigh
  11. #10
    Bob if it doesn't work with @LeighC I'll grab it, my Patrol is what you had.
