Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: GQ RB30 EGR Exhaust Manifold
    Dec 2017
    Sunshine Coast
    Got it sorted in the end. I cheated and ended up using a local bloke from Mobile Thread Works (http://mobilethreadworks.com.au). Highly recommended.
    Thanks again all for your help
  2. The Following User Says Thank You to lsmitti For This Useful Post:
    mudnut (7th July 2018)
  3. #22
    84 Post(s)
    Thanks for the feedback. Did you notice any increase in power? I got close to to a ten percent increase on the dyno (the graph is posted on the RB30 thread) and noticed it straight away on the road. Economy was way better as well. I removed the heater grid under the carby, smashed out the centre and refitted it.
    I have also found the snorkel lets the engine breathe better, too. I block off the pre-heat flap vacuum line with a ball bearing during the warmer months, which also aids economy.
  4. #23
    Dec 2017
    Sunshine Coast
    Noticed more power, especially on long highway inclines.
    The heater grid i assume has been gutted as the plug was not plugged in when i bought it. I'm having issues with the carby at the moment so will no doubt need to remove the carby soon.. I'll check then!
    I'll suss out the pre-heat flap vacuum line once I have her running well again, tapped the top radiator hose while checking voltages on return fuel solenoid last night and the plastic pipe fitting broke off the radiator
  5. The Following User Says Thank You to lsmitti For This Useful Post:
