Results 1 to 4 of 4
Thread: No aircon or sub fuel power
    Jul 2018
    Hi, I have a 2006 GU Patrol wagon with ZD30 motor. I have a problem with fuses blowing on my aircon and sub fuel switch. We have tried disconnecting the module to the sub fuel tank in passenger side kick panel and disconnecting the wires to the switches. It still blows fuse. I suspect a wire issue so I need a good wiring diagram to check this out. Can any one help me.
    334 Post(s)
    Hi mate rhebsub tank pump is easily accessable under the car. Disconnext the wores and see if your still blowing fuses. Multimeter will test continuity there too
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Steve hunt (4th July 2018)
    Jul 2018
    Thanks for the reply. I have done that already and fuses still blow. I suspect a wire short somewhere under the dash. That's why I am after wiring diagrams so I can trace wires etc.
