Page 105 of 136 FirstFirst ... 103104105106107 ... LastLast
Results 1,041 to 1,050 of 1356
Thread: All Things Chev
  1. #1041
    Expert Ian2011's Avatar
    Sep 2011
    Australia
    Thanks for the info peeps. Probably better off getting the alloy than continue toe repair the old style.
    6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
  2. #1042
    FWIW mine came with an alloy from previous owner (unknown brand) and kept falling apart on the local rough roads. Changed to a local brass for over say 4 years now without issue and are comfortable in the knowledge I can fix it myself out there if ever needed. Was told that alloy is more efficient though so opted for a very open/spread core brass that seems to be working great. Can get the core model number if you need for secondary quotes mate?
  3. The Following User Says Thank You to MB For This Useful Post:
    Ian2011 (28th June 2018)
  4. #1043
    Sep 2011
    Australia
    That would be good. Natrad say mine is full of holes yet it doesn't leak from anywhere except the filler neck. They couldn't find any replacements tanks and want to fabricate new radiator
  5. The Following User Says Thank You to Ian2011 For This Useful Post:
    MB (28th June 2018)
  6. #1044
    No problem, give me 10 mins mate.
  7. #1045
    ‘Y7452’
    My local builder also plumbed the bottom end from passenger side across to gain as much water crossing as possible.
    In their stock form (yanky trucks) I believe our 6.5 Chev’s have the TS top housing facing opposite so this is not needed for crossflow. Disregard my thermo fans, awesome in the slow bush tracks but not much chop on the highway hauling.
  8. #1046
    A better radius bend bottom pipework setup would have been nicer though if done again!
  9. The Following User Says Thank You to MB For This Useful Post:
  10. #1047
    Sep 2011
    Australia
    Thanks for that mate. Will help me out today with the ring around
  11. The Following User Says Thank You to Ian2011 For This Useful Post:
    MB (28th June 2018)
  12. #1048
    Jul 2018
    Hi all. I have just acquired a 2001 patrol wagon with a 6.5 turbo chev. I have been doin a bit of reading about them and found out that there is a stronger version of the motor called the p400. How exactly do i know if i have a p400 or not?
    Keen to find out what i have.
    Motor installed in 2013 and has about 45000 on it now.
    It was a new crate engine.
    Thanks!!
  13. #1049
    The P400 has a reinforced bearing girdle so is approx 3" taller than the Optimiser or earlier 6.5. @poindexter is installing one into a GU ute right now, so should be able to give you more clarity. Failing that do a google search and I think the difference is obvious. I would be surprised if you had the P400 as they are more difficult to fit than the other engines. I have the Optimiser n/a fitted to a GQ
  14. #1050
    https://www.youtube.com/watch?v=UEaX3H_lBAY
    Have a look at this clip, especially around the 1min 40 mark. It shows the engine in detail and the extended bottom girdle
  15. The Following User Says Thank You to PeeBee For This Useful Post:
    MudRunnerTD (19th October 2018)
