Results 31 to 40 of 40
Thread: How the bleedin heck do you change oil filters?
  1. #31
    Jul 2015
    Camden NSW
    6 Post(s)
    Park with one side on gutter, bricks, or something to have filters slightly downhill. Drain engine and then drive a large "stumpy" screwdriver into the filters. Drain and then remove.
  2. The Following User Says Thank You to bazzaboy For This Useful Post:
    Hodge (13th October 2017)
  3. #32
    176 Post(s)
    Quote Originally Posted by bazzaboy View Post
    This is exactly what i do.
    Dump the oil . And then jack the passengers side right up as much as possible so oil in the filter stays in the filters due to created anti-spill angle. Then stuff a few rags under the filters.
    Take fuel filter assembly off and tuck to the side . Take oil filters off. Minimum mess.
    If changing fuel filter . Hoses off. Unbolt the unit. Drain excess diesel out of it.
    Then bolt it back on upside down and unscrew.
    Bobs your aunty !
    Dec 2015
    WA
    5 Post(s)
    I just found this, I haven't owned a TD42 for a long time.
    OMG this has been made difficult, a 2 litre ice cream container wedges in under the filters perfectly & catches almost all of the oil.
    Graham
  5. The Following User Says Thank You to GeeYou8 For This Useful Post:
    growler2058 (9th June 2018)
  6. #34
    476 Post(s)
    Quote Originally Posted by GeeYou8 View Post
    Graham
    I just buy a spray can of engine degreaser everytime I buy the filters. Let the oil run its path then use the entire can of degreaser on the affected area. Lol.
  7. #35
    Ballarat, Vic
    176 Post(s)
    The method I seem to have adopted is
    1. Use a chain type filter wrench
    2. Unbolt fuel filter & tie off to one side
    3. move vacuum hoses out of the way
    4. Loosen each filter, one at a time, when loose enough to undo by hand place a plastic bag over the filter (supermarket shopping bag) & as soon as the filter is free tip it upright.
    5.Still doesn't catch every drop, but it does result in less spillage.
    Whoever thought horizontally mounted filters in a spot requiring 'rubber' arms to remove them was a good idea obviously didn't have to change them.
  8. #36
    Whoever thought horizontally mounted filters in a spot requiring 'rubber' arms to remove them obviously didn't have to change them.
    Or still holds a grudge and is getting even after the Grandparents got nuked back in '45
  9. The Following User Says Thank You to the evil twin For This Useful Post:
  10. #37
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Thankfully age hasn’t dulled your wit ET, always entertaining hearing from you.
    Jack
    2024 Isuzu MUX
  11. #38
    Mar 2020
    Anyway to find out if Chicken has at least one of these unit available for me to buy?
    Thanks.
  12. #39
    176 Post(s)
    Quote Originally Posted by Canigetanamen View Post
    Thanks.
    Just message him direct. I think he roams around on the other Patrol forum.
    Feb 2012
    I pull the sump plug and let it drain overnight, then remove the filters the next morning.
    Most of the oil in the filters runs back into the sump (anti-drain back valves don't work very well).
    I slip a shopping bag over the filters before spinning them off.
    It doesn't stop all of the mess, but it does greatly reduce it. A couple of rags up under the filters catches any dregs
