Results 11 to 20 of 22
Thread: can i put front twin piston calipers from 92 efi into my 91 carby.
    Apr 2018
    oh ok so im on the right track then, thanks for your help mate. seeya around hopefully.
  2. #12
    I have rhe clip you need but would be taking it out of a complete caliper which is probably no big deal ro be honest. Going the twins will be best mate.
    No master upgrade. Direct bolt. Winner.
  3. #13
    Expert billyj's Avatar
    gordon
    yep caliper, caliper bracket, disc and backing plate is all you need and it will all bolt straight on
    gone to the dark side 2017 vdj 79 dc
  4. #14
    Yes your twin piston calipers are a direct bolt on upgrade.
    I'll have a look through my spares too mate cos I kept the old calipers so may have those clips. I'd be doing the upgrade if I were you though mate, the difference is insane!
    Where did you source your parts from for this upgrade Winnie? I have 1997 model. Would patrol a Part be a good start? Also is it just the caliper and do the pads change as well? Did you do anything to the brake booster?
  5. #15
    Brake booster is unchanged. You will need the new calipers, pads and rotors. Make sure you get the bolts for the calipers because they are longer.
    I actually bought mine through the marketplace on this forum about 3 years ago. I saw a set for sale on Facebook in nsw today I'll see if I can find it for you.
    These calipers were only found on TB42 efi Patrols.
  6. #16
    Thanks Winnie, I am not on facebook so if you do find I hope here is a phone number. What sort of cost?
  7. #17
    Apr 2018
    yea thank billy backing plate too you say good thing i caught that thats the only thing i haven't pulled of the 92 yet i did notice there a lil different is that like a lil wind scoop on the opposite side to the caliper on the backing plate?.
  8. #18
    gordon
    yer its a little scoop for cooling, the cut out for the caliper is larger as well
  9. #19
    176 Post(s)
    Has no relevance to me .............. but this is a good thread.
  10. #20
    476 Post(s)
    All those scoops are good for in letting mud. I destroyed two new rotors and new pads a while ago whilst attempting a bog hole. Needless to say I got stuck and stuck good. Zero front brakes for the rest of the day.
