Page 154 of 187 FirstFirst ... 152153154155156 ... LastLast
Results 1,531 to 1,540 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #1531
    334 Post(s)
    Well the last few weeks ive spent fitting barwork. What a mutha fuka that has been.
    The sliders where a pig to get back on. Heavy and very short bolts that didnt want to start. I had the make some adjustments to holes with the die grinder to get them on. Lets just say there where some dark days spent laying on my back.....
    So after finally getting the sliders i found the bolts used on my old bar where too short for the new rear bar bu 10mm! so had to buy more this week. They are a rate 14mm bolt. When i took on into the bolt bloke he looks at me and gave me a concerned look and walked away!!! Im thinking WTF?? That aint good!!! Rare and bloody dear!!! Nearly $10 EACH!!!
    So when fitting the rear bar it became clear that things had moved while welding off. I had tacked everything on the car bolted in postion. When i finish welded the tails on the sliders for the rear scrubbies they both creeped forward damn it so needed some clamping to bolt up. They where misaligned by 10mm. Both sides.
    Given how heavy things are and trouble with only having Naomi and Zach to help it was a slog. I was surprised then to find the bolts for the camburgs binding hard. Damn it 8 needed to run a tap down every thread which i didnt see coming at all.
    Then this happened!!! MUTHA FUKA!!!!!
    took some getting out and a mate dropped in at the right time and we for it out with some patience and motivation! Kinda smashed me though!!
    I had a spare tap so ran it into every other one. I was surprised how much cut was needed ro clean the threads. It was almost luke cutting s new one in every hole. No wonder i broke a tap.
    Advice to ALL - DONE BREAK A HARDENED TAP EVER!
  2. The Following 4 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (27th May 2018), MB (27th May 2018), NissanGQ4.2 (27th May 2018), TPC (28th May 2018)
  3. #1532
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    14mm x what Daz and what pitch, would hardly call 14mm a rare size
  4. #1533
    334 Post(s)
    Whats going on here???
    For those mental moments!!
    I know right!! Kool as hell! Mad as faarrkk!!
    The other side next weekend with a switch in the centre console.
    2 x 1100Gal/hr Bilge pumps for the win!!
    Fully Sik!!
  5. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
  6. #1534
    334 Post(s)
    I think 14 x 1.5
  7. #1535
    Looks awesome Daz, beast is nearly there mate, top stuff!
    How on earth though are you going to explain the bilge outlet staring straight at Mr Plod drivers side? Maybe just give him a quick squirt and ‘bail’ outa there even quicker :-)
    Rossco (31st May 2018)
  9. #1536
    334 Post(s)
    Lol. Im All In mate! Hopefully he finds them amusing
  10. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    MB (27th May 2018)
  11. #1537
    Now that is a dedicated beer drinker!
    No more wasted beer spillage on the ground just wrap your lips over the B pillar!
  12. The Following 2 Users Say Thank You to AB For This Useful Post:
    MB (27th May 2018), MudRunnerTD (27th May 2018)
  13. #1538
    198 Post(s)
    Looks like that tap is dry - no lubricant. Bit of a lesson there. Regardless of chasing out a thread or tapping a new one, always use lub as the task is very high friction at best. Those coulpings must be pretty hard as well I am guessing? How close to the threads are your welds as maybe they closed up a fraction from that?
    Anyway, mean set of rails darren, but don't ever call my barge heavy after seeing these!!!!
  14. The Following User Says Thank You to PeeBee For This Useful Post:
  15. #1539
    Rogue Dung Beetle djc123's Avatar
    Oct 2011
    WHAT!?! A Nissan driver that’s run out of lube? Now I’ve heard everything.
    Its a Toyota! =====> Its a Keeper!! ....... Got an LS2 in it BONUS!! Wish it was Nissan though, Toyotas just can't keep up with the Pootrol pace.
  16. The Following 3 Users Say Thank You to djc123 For This Useful Post:
    AB (27th May 2018), MudRunnerTD (27th May 2018), PeeBee (27th May 2018)
  17. #1540
    334 Post(s)
    Nah i was using wd40 as lubricant. They where definitely wet. I had sprayed it clean with wd40. In that pic too using the WD to wash out the tap
  18. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    PeeBee (28th May 2018)
