Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: GQ Alternator upgrade??
    Have a look at this link. MB and I bought the 420 amp units, cost me $110 for the auto elec to add the cables into the alternator, then I fitted the 'box'.
    https://alternatorparts.com/quicktif...rectifier.html
  2. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB TD42 (21st May 2018), SteveT61 (2nd November 2025)
  3. #12
    84 Post(s)
    @PeeBee. Interesting concept. Have you installed a clean air inlet to the fan? I was thinking that some sort of pipe from you snorkel might do the trick. And I am very curios to know if you gained or lost a few RPM compared to before installation when the alternator was under load.
  4. #13
    The box is open to the under bonnet environment. I initially was going to mount it inside the cabin, but it is designed for the duty so left it stock standard and just mounted it up high on passenger side behind the alternator. Regards performance, it simply allows easier current flow so no detectable drag. I have however picked up a better voltage charge rate, which is understandable. The little mitsubishi pajero alternator supplied by Brunswick Diesels would only ever charge to say 13.8v, have had 2 of them now, same charge profile, but with this box, I get the full 14.4- 14.6 on start up then it tapers off as expected.
  5. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB TD42 (21st May 2018), mudnut (16th May 2018)
  6. #14
    Expert Dingbat MB TD42's Avatar
    Jan 2018
    Perth WA
    Cheers fellas, I will be looking into this when upgrading for sure.
    Quad-Drive 4WD Club...Western Australia
    We're all here coz we ain't all there...
