Results 1 to 9 of 9
Thread: 11 volts to glow plugs
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Yeah I know time of year that there is heaps of questions about slow starting and glow plugs but just checked mine for voltage and I'm getting 11.06 volts which to me sounds low but can't find info on what it should be ,assuming it should be whatever the battery is at .
    Also noticed they come on for maybe 2 secs then turn off then turn on again for three cycles .
    Would imagine it should be higher than that. When mine come on they definitely bring the battery voltage down cos they draw a shit load of current, but it stays about 12V
    Turning off and on is normal behaviour.
  3. The Following User Says Thank You to Winnie For This Useful Post:
    GQtdauto (13th May 2018)
    22 Post(s)
    Disconnect the supply wire to the glow plugs and check voltage there. It's likely to be the glow plugs dragging it down if battery voltage it ok.
    96 GQ coil/Cab
    08 G6eT
  5. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    198 Post(s)
    Mine drop to around 11.5V, checked this with auto elec and said it was about right, indication only for comparison as not nissan set-up
  7. The Following User Says Thank You to PeeBee For This Useful Post:
  8. #5
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Hadn't thought about the sudden drop in voltage you get when all six get power in an instant , battery was 13.3 volts so doubt that played any part .
    Motor started ok and hasn't been started since last Thursday ,will disconnect the feed wire and recheck but feeling better about it thanks to all the above .
  9. #6
    May 2016
    8 Post(s)
    Yes that about right just checked mine
  10. The Following User Says Thank You to Tip12345 For This Useful Post:
  11. #7
    Dec 2015
    WA
    5 Post(s)
    Measure the voltage from battery +ve to glow plug bus, over half your voltage drop will be here, the rest on the earth return.
  12. The Following User Says Thank You to GeeYou8 For This Useful Post:
    GQtdauto (14th May 2018)
  13. #8
    Aug 2018
    11 volts no worries at all, glow plugs are high amp users and will pull the voltage down. A good sign as it means they’re working!!!
    Just replaced all for ona four cyl Mazda 3 litre, hard starting or won’t start. All four u/s
  14. #9
    Dec 2016
    Northeast Victoria
    41 Post(s)
    As a footnote although the voltage was up I have a three battery system with roof solar and just before leaving for the trip the crank battery shit itself ,no trouble starting it up north but back here in the cold it does crank a few more times before starting .
