Results 1 to 10 of 12
Thread: No power at all
    Sep 2017
    Nowra
    No power at all
    I’ve just installed a new alternator, before starting the install I removed earth strap off the battery, I installed alternator and went to put earth back on battery and it sparked the the positive side had some smoke,
    Now I have no power at all.. I’ve been through all fuses and found a 10amp from under dash blown so I replaced it. It was for eng cont
    It’s a td42 converted using all Tb42e wiring, there is one wire that goes to the battery that controls everything power wise but I don’t know where to look for fuse or relay that’s directly to that wire.. if anyone can help me shed some light on what happened that would be great! I’m going a little bonkers 😅
    I think there are a couple of man fuse blocks in the small enclosed fuse box under the bonnet - on drivers side - next to guard - you need to unscrew the op panel to access - they look like relays boxes from memory. By some chance you didn't hook up the pos and neg battery cables in reverse on the alternator? Sounds like a main fusable link also? Can't recall where that is though.
    Sep 2017
    Nowra
    nah mate I only removed negative from battery and I don't believe I did as far as alternator I just copied how it was already installed but I will have a look over incase I have mucked something up, also I have looked at those relays but everything looks fine? I'm not really sure what to do from here...
    OK< there re also some big fuses in there as well, brown ones, green ones and white I seem to recall. One of those actually drops off all power to the vehicle - I think @AB might even remove his on occasion as an anti theft deterrent? I know the car wont run if its blown, or at least thats what happened on my GQ 2.8 once when I shorted out a cable. If the blue topped relays are damaged they would probably have signs of melting on the top covers, but sounds like they are ok.
  5. #5
    Sep 2017
    Nowra
    yep I've checked them also and all is fine I'm really confused on whats happening... do the tb42e have a body control system? maybe I've burnt that out? I'm just so confused on how it even happened when all I did was remove neg cable from neg battery post swap alternators then put neg strap back to neg post...
  6. #6
    Nope, I am out on this one now, sorry.
  7. #7
    84 Post(s)
    The fusible links are near the positive battery post. They have plastic connectors on each end.
  8. The Following User Says Thank You to mudnut For This Useful Post:
    PeeBee (22nd March 2018)
    Sep 2017
    Nowra
    checked all them too mate all A OK, I'm so stumped..
  10. #9
    Sep 2017
    Nowra
    Quote Originally Posted by BrodieTiGQ View Post
    This is the main power , where’s the fuse or relay for this?
  11. #10
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    In mine there under a cover just to the right of your hand and just below where you have your hand , because it's been converted it's all different .
    But if when you touched the leads the dreaded smoke came out something's amiss with the way you hooked the alternator up or possibly something was left on .
