Page 42 of 64 FirstFirst ... 4041424344 ... LastLast
Results 411 to 420 of 635
Thread: Rosscos GQ Rejuvenation
  1. #411
    Bennyboy, we got Rosscos head off today, was a bitch but some sledging, prying and rattle gunning we finally got it of
  2. The Following 4 Users Say Thank You to AB For This Useful Post:
    GQtdauto (13th January 2018), Maxhead (13th January 2018), MB (13th January 2018), Rossco (13th January 2018)
  3. #412
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    So no chance of blowing the head gasket anytime soon .
  4. #413
    Patrol Guru matfew's Avatar
    Nov 2012
    Why's the head coming off???
  5. #414
    Quote Originally Posted by matfew View Post
    Just decided to give it some love seeing as I'm half way there. . . Plus don't think I've spent enough on the thing for a few months . . .
  6. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    AB (13th January 2018), GQtdauto (13th January 2018)
  7. #415
    22 Post(s)
    At least you took the rocker shaft this time
    96 GQ coil/Cab
    08 G6eT
  8. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    AB (13th January 2018), Rossco (13th January 2018)
  9. #416
    For anyone interested in getting the Borgwarner, I helped Rossco rotate the compressor and central alignment for his manifold today.
    For a direct down compressor outlet app the wastegate was absolutely spot on to snug fit beside the recirculation valve.
    Like 2mm gap thankgod!
    I've never seen or obviously set up one like that but was perfect!
  10. The Following 2 Users Say Thank You to AB For This Useful Post:
    GQtdauto (13th January 2018), Rossco (13th January 2018)
  11. #417
    Yeah looks pretty good now all set up to mount up to the old dts manifold and safari front mount intercooler. Pretty lucky with everything seems to fit perfect. Reckon if we didn't have the outlet facing down would be getting very close to the block with the compressor side where it bulges out as dts doesn't have much angle facing out in the flange compared to the factory turbo manifold at least.
    Got all fittings from Pirtek just need a couple of crush washers and 4" to 2.5" silicone elbow to go from airbox to turbo.
    Drop the head off on Monday to Omar from go2 engines see what he thinks. . .
  12. The Following User Says Thank You to Rossco For This Useful Post:
    matfew (14th January 2018)
  13. #418
    Patrol Guru
    Jul 2014
    6 Post(s)
    How's this thing going? Any more updates? Cleanest GQ I think I've ever seen.
  14. The Following User Says Thank You to Throbbinhood For This Useful Post:
    Rossco (21st March 2018)
  15. #419
    Oh yeah so. . . Had been meaning to give a bit of an update with the old thing but been kinda flat chat with things lately it's been crazy . .
    So I ended up getting a little bit carried away with the motor and after pulling the head and and doing some cleaning of the block found a bit of carbon scoring in the bores (only a couple). Did a leak down test using some 2 stroke held fluid pretty well but one thing led to another and pulled the motor down for a strip and rebuild. Taken a while but should be ready to pick up tomorrow hopefully. Think I figured that while I'm here do the head, then thought half way there to do the bottom end too, plus kays were getting towards 400 and keen on doing some big trips in the future so will be good peace of mind knowing its all fresh. Keen as to get it going, has been balanced so hopefully is a bit smoother than before.
    Everything is ready to go back together now, had to repair a couple of threads in the bell housing from when my mate just smashed a couple of bolts in with the rattle gun. (grrrrrrr )
    Anyway should be up & running by easter then get some kays on it before a tune hang'n to get back into it TBH.
  16. The Following 5 Users Say Thank You to Rossco For This Useful Post:
    Bacho86 (21st March 2018), GQtdauto (21st March 2018), MB (21st March 2018), mudski (22nd March 2018), PeeBee (21st March 2018)
  17. #420
  18. The Following 4 Users Say Thank You to Rossco For This Useful Post:
    Avo (21st March 2018), GQtdauto (21st March 2018), MB (21st March 2018), Woof (21st March 2018)
