Page 824 of 1057 FirstFirst ... 822823824825826 ... LastLast
Results 8,231 to 8,240 of 10566
  1. #8231
    WA Wheatbelt
    23 Post(s)
    it's a date then.....
    Fantastic. I'll be in touch.
  2. The Following User Says Thank You to DX grunt For This Useful Post:
    Avo (17th March 2018)
  3. #8232
    477 Post(s)
    Removed the alternator. I had to remove it with the mounting bracket that bolts to the engine block as the A/C pipe is about 5mm behind the lower mounting bolt so I couldn't remove said bolt. Lucky the bracket wasn't too hard to remove...
    MB (25th March 2018)
  5. #8233
    Nov 2010
    Getting a life...
    38 Post(s)
    Took the usual dargo shot...
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  6. The Following 2 Users Say Thank You to katwoman For This Useful Post:
    MB (25th March 2018), Plasnart (18th March 2018)
  7. #8234
    Expert Dingbat MB TD42's Avatar
    Jan 2018
    Perth WA
    Checked the Valve clearances on the TD42...as well as I could...lol...washed the dust from last weekend off.
    Bought a spare steering box and cheap GME3200UHF together for $120 all up
    Quad-Drive 4WD Club...Western Australia
    We're all here coz we ain't all there...
  8. The Following User Says Thank You to MB TD42 For This Useful Post:
  9. #8235
    Got it dirty
  10. The Following 4 Users Say Thank You to jay see For This Useful Post:
    katwoman (19th March 2018), MB (25th March 2018), mudnut (19th March 2018), mudski (19th March 2018)
  11. #8236
    Installed a 'quick t verter' device to the charge circuit of the main alternator. Its a rectifier pack that splits the load across 18 diodes instead of the standard 6, hence allows for the rectifier diodes to individually run cooler and increases charge efficiency. What I have found since installing it is that the main battery voltage does not drop when on high beam, all driving lights on. Before installing it the voltage would gradually fall and the alternator could not keep up - is a small mitsubishi pajero 100amp unit installed by Brunswick Diesel as part of the Chev conversion. There is a bit of minor work to do to the alternator, but looks good. here is the link to the device. I and @MB have purchased the 420amp units. They don't boost the output, just decrease the load over more diodes. Both our Chevs run hot and alternator death has become the norm of late - hoping this fixes it.
    https://alternatorparts.com/quicktif...rectifier.html
  12. The Following User Says Thank You to PeeBee For This Useful Post:
  13. #8237
    A successful day.
    Installed the redarc gauge
    Took it to the car wash to leave the mud behind.
    Rotated the tyres well overdue, but it's now done.
    Loaded up the trailer with all the bigger things that can stay in there for a few days in preparation for a Thursday night departure.
    Fixed the Uhf issues, I hope.
    And gave it a well deserved bath (between the showers) and vacuum.
    Scrubs up alright. She'll be 21 towards the end of this year.
  14. The Following 3 Users Say Thank You to jay see For This Useful Post:
    MB (25th March 2018), mudnut (25th March 2018), PeeBee (24th March 2018)
  15. #8238
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Replaced the damaged rear abs sensor after picking up a second hand part from patrolapart this morning
  16. The Following User Says Thank You to Bacho86 For This Useful Post:
  17. #8239
    177 Post(s)
    Just ripped out the cruise control vacuum/motor and the pull-cable all the way to the pump.
    Gained ample room for the Catch can. Perfect spot.
  18. The Following 3 Users Say Thank You to Hodge For This Useful Post:
    Bacho86 (25th March 2018), GQtdauto (25th March 2018), MB (25th March 2018)
  19. #8240
    483 Post(s)
    Cheers again Philstar for kindly getting these Quicktifier jobbies in mate! I’m running a bit behind your efforts mate but managed this arvo to bolt the 170amp GQTD42 alt back in after its birthday with 3 x phase wires at the ready! Just needs final connections now and away we winch/fridges/lights/fans galore up and running again for now ;-)
