Results 1 to 7 of 7
Thread: Reversing rear tailshaft
    Expert JackoGQYoot's Avatar
    Oct 2017
    WA
    Hi guys,
    After putting the lift in, I have realised there is about a 10mm gap between the tailshaft and the crossmember, which could hit when driven off road. Would any of you be able to tell me how difficult it is to flip the rear tailshaft? would i be able to do it myself?(little mechanical knowledge and no proper mechanics tools)
    Td42 coily
    Undo 8 bolts and flip it no dramas
  3. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Evo (22nd February 2018)
    Oct 2017
    WA
    Does any oil come out of the gearbox, transfer case or rear diff that I need to worry about?
    Td42 coily
    Quote Originally Posted by JackoGQYoot View Post
    Nah mate... well... Only if something was already broken that you did need to worry about anyway
  6. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    Evo (22nd February 2018), JackoGQYoot (22nd February 2018)
    84 Post(s)
    Make sure the seal is in good condition or you will get moisture and dirt into the spline. If you have to replace it, mark both pieces of the shaft so that you can put it back together properly.
  8. The Following 3 Users Say Thank You to mudnut For This Useful Post:
    Evo (22nd February 2018), JackoGQYoot (26th February 2018), the evil twin (22nd February 2018)
  9. #6
    Patrol Guru Evo's Avatar
    Jun 2013
    Lost somewhere in my own head...
    Easy to do. As above, 8 bolts to undo, flip, 8 bolts to do back up. Put the vehicle in gear, and into 4x4 with hubs locked so there isn't any chance of the vehicle moving when the shaft comes out.
    Cheers,
    Evo
  10. The Following User Says Thank You to Evo For This Useful Post:
  11. #7
    Very good point...
