Page 102 of 136 FirstFirst ... 100101102103104 ... LastLast
Results 1,011 to 1,020 of 1356
Thread: All Things Chev
  1. #1011
    @MB, here is another belt option. 1) Space the alternator out by 1 pulley sheeve and run the existing belt off the rear groove. Buy a 4 sheeve pulley for the crank and the water pump and run the additional belt so now both belts will be the same. You will need a double adjuster pulley as well. Its a bit more work, the additional overhung load on the front bearing will be minor i believe.
  2. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (23rd January 2018)
  3. #1012
    Apr 2013
    Upper Ferntree Gully
    22 Post(s)
    You seem to be going through a lot of effort on this charging thing.
    200amps would be more than enough in my view.
    I haven't read all 101 pages of this thread, but I don't get why you want 800amps charging capability? have I missed something.
  4. #1013
    Ralph, unsure who this directed at MB or me? I don't know what the 800amps refers to either - maybe clear that up first eh.
  5. #1014
    Apr 2013
    22 Post(s)
    POST #1008 : I have already sent this link to MB for his info. I will be buying 2 off the 400 amp units for fitment to my 100amp and 200amp alternators next month.
    I assume you are replacing the 2 Alts with these 2 400amp Alts
  6. #1015
    Quote Originally Posted by poindexter View Post
    OK, sorry. We are talking about the diode pack/rectifier upgrade only, not the alternator. I agree 2 x 400amp alternators would be an overkill unless you wanted to winch all day and the wiring upgrade would be a pain as well.
  7. #1016
    My "PeeBee Special" oil cooler arrived and very nicely engineered I must say now I've seen it in the flesh.
    I'll definitely wack it as soon as possible after I sort out the unions required if I use the existing oil cooler pipes.
    Thanks for putting us onto them Cobber
  8. The Following User Says Thank You to the evil twin For This Useful Post:
    MB (30th January 2018)
  9. #1017
    No problems. I was driving mine around in 40 degC over the weekend and it was cooling the oil by 30 deg however its noticeable that this decreases when the vehicle is stationary as it becomes a simply radiation temp shedding instead of having the temp being stripped off via a convection method.
  10. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (30th January 2018), the evil twin (30th January 2018)
  11. #1018
    All Things Chev
    Thought it best to post up here a small issue found on the new fibreglass bonnet 4hr highway test run in very high ambient moderate hauling heats recently. Doesn’t really bother me but the flexing/curling of the width of it may aesthetically upset a buyer looking for perfect panel lines, Cheers!
    EDIT: This could possibly be a reason for the found instructional sticker atop of its arrival to “Test Fit First Prior Painting” maybe I’ll look at a matched white vinyl wrap again for flexibility like my old TD42T steel work bonnet logo cooker :-)
    EDIT-2: Bake the cake prior to icing;-)
  12. #1019
    MB, this should warrant a call to the manufacturer I reckon. based on it supposedly being a direct replacement this is horrible.
    Secondly, no idea what the two edits mean, so again, full marks to the secret message to the beasts who can understand it!!!
  14. #1020
    Apr 2013
    22 Post(s)
    looks almost 5mm too narrow on both sides, could just be parallax error tho....
  15. The Following User Says Thank You to poindexter For This Useful Post:
    MB (1st February 2018)
