Results 1 to 10 of 12
Thread: Jeep Cherokee Question
    Jan 2018
    Looking at buying a 6cyl 4.0L 2000 Jeep Cherokee for $7500 with 245,000KM clocked on it but the previous owner overhauled the engine 40,000KM ago, i read that Jeep Cherokees are really reliable if maintained well and so on and the current owner claims to be a mechanic and that he has looked after the car very well. He sent me a list of modifications done to the car and engine also pictures of the car as well which is listed below;
    https://imgur.com/a/76eBx <<<<< Pictures of the car
    ENGINE
    - Engine completely and meticulously overhauled
    - Crankshift ground 10 tho, new big ends and main bearings
    - Resized conrod tunnels
    - 30 thou over size pistons and rings
    - New camshaft bearings
    - New brass welsh plugs on block and head
    - Block acid washed, decked, bored and honed
    - Completely overhauled cylinder head
    - New mopar hydraulic lifters
    - New mellings pushrods
    - New dorman harmonic balancer
    - Fully quality seal and gasket kit
    - New dorman camshaft synchroniser
    - New spark plugs and ignition coil pack
    - New MAP sensor and crank angle sensor
    - New cylinder head bolts
    - New water pump, thermostat, thermostat housing
    - New oil pressure sensor and coolant temp sensor
    - Machined exhaust manifold and manifold studs and nuts
    - New drive belt pullies and drive belt
    - New adrad brass/copper radiator and cap
    - New radiator hoses/clamps, coolant
    - 6 New bosch upgraded 4 hole pintle injectors
    - New viscous fan hub
    - New mopar oil filter housing seal kit
    - New PCV valve
    -K&N air filter
    OTHER
    - Brand new Dana 35 tru trac rear differential lsd centre and bearings
    - New RACQ 500cca battery
    - All new driveline oils
    - New rear wheel bearing kits
    - Complete professional automatic transmission service and flush
    - New torque converter seal
    - New steering dampner
    - New front brake pads and rotors
    - New rear drums, shoes and cylinders
    - Full brake fluid flush at master cylinder and all calipers
    - Though dog front and rear heavy duty springs and shocks absorbers
    - Cooper ATR discoverer tyres
    Basically want thoughts about the car as a first car and some information about the reliability of the car as im only concerned about the high milage and the overhaul!
    Jan 2018
    Pt Augusta SA
    might pay to go to a Jeep forum for answers as they would have a better idea or just buy a Patrol.
    Only thing I know about Jeeps is what I observed in my rear view mirrors IE they get smaller the further behind me they are...
    I believe they came new with a free Pressure Washer so you could wash the oil off your drive each week but not sure
    I would suggest join this Forum for your Jeep Q's Cobber http://www.ausjeepoffroad.com/forum/index.php
    82 Post(s)
    If it so good, why is he selling it?
  5. #5
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    jeeps were so reliable they came with a light under the bonnet ....
  6. #6
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Don't forget to buy a couple of big fire extinguishers.
  7. #7
    Their slogan is "Theres only one Jeep" you may have just found it lol
  8. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    GQtdauto (24th January 2018), growler2058 (24th January 2018)
    Quote Originally Posted by Jiggy View Post
    ENGINE
    - New PCV valve
    -K&N air filter
    OTHER
    i would presume that this bloke has had a gutful of it,,why would someone put all those new bits on it only to sell it,,in all honesty when i see a car with new this and new that,i tells me a story.......
  10. #9
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Also my son bought a GU ute that had the itemised receipt for an engine rebuild only to find out a thousand Kay's later that it was a shonk receipt and the motor blew up .
  11. #10
    wasa it you guys who bought it from a mechanic..someone here mentioned something simular not long ago...that's suck big time
