Results 1 to 8 of 8
Thread: Wind Deflectors
    Expert Tonks's Avatar
    ACT
    Wind Deflectors
    Hi all,
    I'm after a set of front wind deflectors, the slim line type,
    Where would i get a decent set from,
    Cheers Tonks.
    2004 GU111 4.2 TURBO WAGON, 2" OME SUSPENSION, 33" MTZ's, 3" BEAUDESERT EXHAUST, ARB ROOF RACK, ARB AWNING, BLACK WIDOW DRAW SYSTEM & CARGO BARRIER, DUAL BATTERIES, 12,000lb WINCH, GME UHF, LIGHT FORCE XGT SPOTTIES, BERRIMA DIESEL TUNE.
    334 Post(s)
    EBay for the win. Search "Nissan Deflector"
  3. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    Perkins58 (10th December 2017), threedogs (5th December 2017), Tonks (3rd December 2017)
    198 Post(s)
    Don't go too slimline as the water tends to drip inside the vehicle - found this out on my GQ and wished i had gone for a wider/deeper profile. No advantage on the move either as the wind is still significant into the vehicle with the window down a little bit. I remember the big old window deflectors and the ol' man would have the window down on the XW falcon and be smoking away and nothing came into the car, smoke, wind or water, ah memories!
  5. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    GQtdauto (3rd December 2017), Tonks (4th December 2017)
    Had both, prefer the slimline..... Especially when the car is bogged and you cant open the doors..... Only way out is the windows
  7. The Following User Says Thank You to Clunk For This Useful Post:
  8. #5
    198 Post(s)
    You're right on that one as got hung up on a dry bog hole trench last trip and just squeezed out the door but had to climb back inside via the window, so yes the slim lines were an advantage.
  9. The Following User Says Thank You to PeeBee For This Useful Post:
  10. #6
    176 Post(s)
    Had the genuine slim Line tinted ones on both of my GUs. Work great never had issues.
    The only gripe is... They might protect from wind and weather when window is slightly open.
    But they create serious air noise.
    When driving against some head wind it's like a jet engine outside your window.
  11. The Following User Says Thank You to Hodge For This Useful Post:
  12. #7
    Got the full size deflectors. No wind noise and can have the windows cracked. Only prob they make mirror work difficult. Pros and cons.
    Edit, mostly passenger side mirror obstruction. Reversing trailer a biatch for vision.
    Gong him Red!!
  13. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    katwoman (4th December 2017), Tonks (4th December 2017)
  14. #8
    full size make it difficult if you need to stick your head out the window to look backwards.
    I have tinted slimline , just need to crack the back window down an inch and all is good.
    @Hodge mine make no noise at hwy speed maybe check how you mounted them.
    I think the small ones for the rear doors are great at camp to keep the air flowing inside the
    Patrol keeping temps down a bit for the fridge
