Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: P/N Inhibitor - other threads don't have right info
    Expert tuckertrucker's Avatar
    Aug 2015
    Far North, New Zealand
    But, I see the petrol model in the other manual clearly shows that the black yellow wire is live with the ignition ON, and its the other side of the circuit that is switched through the ignition switch. Screen Shot 2017-11-24 at 8.27.06 PM.png
    So basically, earthing the white wire will work. But my truck isn't wired as the haines manual says it is. For some reason mine is wired in the same way as the petrol circuit in the work shop manual. Maybe they did it differently in the 24v trucks cause thats what mine is.
    But it is definately wired this way - we know this because when the ignition is ON (not START) the black yellow wires have power. And the white one is only live when the ignition switch is in START.
    I note that neither of the manuals cover "24 volt Safari's" so maybe that's why the wiring isn't depicted above.
    1992 Nissan Safari Granroad LWB TD42 after market turbo RE4R03A (for now) 3" straight pipe
  2. #12
    84 Post(s)
    https://www.flickr.com/photos/137659...7629319146777/ Try that site. I have found some of the diagrams for the RB30 aren't as they should be, so don't feel left out
  3. The Following User Says Thank You to mudnut For This Useful Post:
    tuckertrucker (24th November 2017)
