Page 150 of 177 FirstFirst ... 148149150151152 ... LastLast
Results 1,491 to 1,500 of 1768
Thread: Ask all your general ( none related forum ) computer questions here
  1. #1491
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    my pc is shgit.old and tierd..lately i cannot do much as it says file not found,when i go into disc cleanup it cannot do that either....so if i upgrade to windows 10 will i have to put all my photos on a disc or will they still be there,and other downloads and documents
    cheers
    If your pc is old and tired Windows 10 will more than likely make it worse not better
    If you do decide 2 install Windows 10 you should not need to backup your photo's and documents but I would anyway just in case something goes wrong, and you should backup your photo's and documents to an external hard weekly or monthly depending on how much info is added / changes
    Download CCleaner to use instead of Disk Cleaner: https://www.piriform.com/ccleaner/download
    What are you doing for it 2 say files not found????
  2. #1492
    Umm nuffink.....nah from what i have read it seems that my hard drive is nearly karputt..cant even do system restore as everything just comes up with pathways broken and ah eap of other crap about recently added shit may have ...and corrupted files..time for a new pc i think..will give thast link a try..
  3. #1493
    Aug 2010
    17 Post(s)
    Do you mean do a system restore or back up using system restore?
  4. #1494
    system restore..
  5. #1495
    84 Post(s)
    post deleted, found how to fix the problem.
  6. #1496
    Patrol Guru
    May 2011
    mackay former alice boy
    Calling all tecos this dinosaur needs some help. I bought a hema hx1 and want to know whats the best SD card to put in or run two as in one for photos vids and one for trips way points etc. So basically brand and size would be good TIA.
  7. #1497
    Aug 2010
    17 Post(s)
    Quote Originally Posted by dads tractor View Post
    I don't have one and never used 1, can you run dual SD cards in it?
    Trips and waypoints probably take up bugger all space so can't see the need for a huge memory card for that
    Photo's and especially vids, the bigger the better. Looking at the specs its only been tested up to 32GB so if you go any larger than that you may have issues.
    As to brand which is better, its sorta like a Nissan VS Toyota debate, pro's n cons on all. I've always used Sandisk cards and never had an issue with them.
    Just look for one that has a good read / write speed
    If you look through the manual it probably states what they recommend
  8. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    dads tractor (2nd January 2018)
  9. #1498
    Aug 2010
    17 Post(s)
    Anyone on here successfully ran an apple app emulator in their android phone?
    @Mike02Ti
  10. #1499
    @Mike02Ti
    Now why would someone want to do something like that
  11. #1500
    SUCH IS LIFE Maxhead's Avatar
    ACT
    @Mike02Ti
    I think OPPOs phone colourOS is apple look and feel software which runs on android
    ________________________
    ______ 2017 D-Max _______
