Results 21 to 30 of 49
Thread: Battery and fridge
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    Yeh GQtauto, Anderson good, have same in tow.
    By the way jay see, I referred to Engel where yours is weaco, same principles apply.
  2. The Following User Says Thank You to Bidja For This Useful Post:
    jay see (17th November 2017)
  3. #22
    Trust you got at least 6mm2 wire/conductors and inline fuses. Engel sockets hook up wire are fused (10 amp fore both +ve & -ve wires).
    When you run your dedicated +ve and -ve wires for the fridge don't use a cigarette / aux socket, get a proper Engel plug and socket (a screw in solid connection). Will avoid a poor electrical connection, the fridge being disconnected resulting vibration or being accidentally pulled out.
    No. I didn't get any wire just yet.
    The dedicated plug at the moment is a merit plug, but I'm not using that one.
    Good advice about the cig plug , I've converted mine to Anderson .
    Yeah I think I will too, once it's all sorted.
    I gather that.
    When I say off the aux battery with a cig plug. This is what I mean.
    Once it's all working properly I'll be using the 6mm2 wire with a twist and lock merit or an Anderson.
  4. The Following 2 Users Say Thank You to jay see For This Useful Post:
    Bidja (17th November 2017), GQtdauto (17th November 2017)
  5. #23
    Aug 2014
    Perth
    10 Post(s)
    I'm assuming your battery is in the back of the patrol, what size wire have you run to it?
  6. #24
    Quote Originally Posted by gubigfish View Post
    Yes it is. Fat wire as big as my thumb.
  7. The Following User Says Thank You to jay see For This Useful Post:
    threedogs (18th November 2017)
  8. #25
    I run my fridge off the aux in a very dark cargo area ,Its only for food and a six pack for the last day.
    Have the esky dripping slowly into a billy as water to hotter than water. make a old radio up in a box to run off a battery box you can top up with some solar.
    never ran out of battery power ever. dont use youe Fridge for drinks it will flatten in now time ,
    If you camp near a town or caravan park take an esky for drinks, cold water to wash your face in the morning priceless
    Mt aux battery is a 115ah wet cell Trojan. would love litium but they over a grand It can wait till the lotto win
    edit I also use a digital temp controller best mod everIMO
    GQtdauto (18th November 2017)
  10. #26
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Yeah lithium is good but the prices not so much .
  11. #27
    OK. I think I may worked out what's going on.
    Last week at around 7pm I loaded up the fridge. Plan was to fill it with water and beer, for the Sunday cricket games and leave it in there.
    Sunday morning ready to go and my son goes out to start the car, he drives to the ground and we set ourselves up.
    Fridge keeps going off.
    I ask him last night. Did you do anything different last week before we drove to cricket? No, 10 minutes later, "oh wait the radio was on but it was muted and the screen was off."
    The radio is connected to the aux battery and you need to turn it on and off everytime.
    He was on the phone writing stuff down when I jumped out. He knows how to turn it off, but must've forgotten to.
    So the radio was on for 15 hours with the fridge.
    I plugged the fridge in last night straight into the battery box at around 6 and checked it just now 11.5v
    The dedicated plug is only a short distance from the junction box may be a metre. Would the 6 mm2 still be recommended or would that be overkill for such a short distance.
  12. #28
    176 Post(s)
    Where & when you do the voltage checking is important.
    What you need to check is the voltage at the fridge when it is running. This probably involves having to rig up something to enable this.
    Reason is to check the voltage drop between battery & fridge.
    No good checking the voltage at each end of the cable when there is no load. Voltage drop increases with the current being drawn.
    It can be a 'vicious circle'. Load increases when fridge cycles on, voltage drop increases, fridge compensates by drawing more current (amps) -> battery discharges quicker.
  13. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    Bidja (19th November 2017), the evil twin (19th November 2017)
  14. #29
    Jul 2017
    40 Post(s)
    Totally agree.......
    jay see, As mentioned earlier on this thread:
    Voltage drop is very important factor to consider and is best to keep the voltage drop below 3%. Can be calculated or measured for a given current flow.
    Noted that your fridge cable run is less than 1m from battery box (in back of veh) and that your charging cables to the batery box "are as big as your thumb" !!!. Both cable runs are important in term of achieving a miniumal/acceptable voltage drop. Both have current flow that can be checked by measurement.
    EG: the fridge run: Hook up Volt meters, one at the battery and one at fridge. Get a multimeter that can measure current flow (not hard to get) and then you can measure the start up and run currents. Hence by taking the reading of both volt meters you can these see the votage drop at the given current flows.
  15. The Following User Says Thank You to Bidja For This Useful Post:
  16. #30
    Wot Cuppa & Bidja said X 2
    I would also make sure you start off your testing with a fully charged Aux.
    Use a Bench Charger to make sure.
    The fridge being faulty can be ruled out 99% of the time and if the battery is good then it means you are looking for either poor charging to the Aux or high resistance/voltage drop in the leads
    Some fridges are a PIA as the low voltage cut is too high from manufacture but it is what it is.
  17. The Following User Says Thank You to the evil twin For This Useful Post:
