Page 82 of 136 FirstFirst ... 8081828384 ... LastLast
Results 811 to 820 of 1356
Thread: All Things Chev
  1. #811
    You blokes are terrible:-)
    Art Whipple wouldn't approve!
  2. The Following 2 Users Say Thank You to MB For This Useful Post:
    the evil twin (27th September 2017), Touses (27th September 2017)
  3. #812
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    FArt Whipple wouldn't approve!
    Fixed it for ya
  4. The Following 2 Users Say Thank You to Touses For This Useful Post:
    MB (27th September 2017), PeeBee (27th September 2017)
  5. #813
    Pharp Whipple wouldn't approve!
    You give us the ammo... we'll keep shooting
  6. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    MB (27th September 2017), PeeBee (27th September 2017), Touses (27th September 2017)
  7. #814
    198 Post(s)
    Guys, further compilation of fuel use on a 300k trio, used 48 liters. 200k of that was at 100km/hr freeway and the remainder a mix of windy gear swapping roads and perhaps 5k of 4wd'ing. So average consumption works out at 6.25kilometer/litre, or 16l/100klm.
    Vehicle sits at 100klm/hr and 2000rpm and hovers around 15.5 l/100klm. I am happy with this as currently sitting at 3600kgs vehicle weight and aerodynamics of a barn. This is a heap improvement on the 2.8TD I had in before the engine swap, it would deliver numbers around the 28-30/100klm.
    EGT's sit around the 250-ish mark cruising along
    MB (5th October 2017)
  9. #815
    Apr 2013
    Upper Ferntree Gully
    22 Post(s)
    Good info that.
    Just curious , where is your EGT probe positioned?, near the head, or further away?
  10. #816
    198 Post(s)
    Quote Originally Posted by poindexter View Post
    Good info that.
    I have a probe installed on each header, or actually as close to the header as I could get it which is say 100mm downstream of the 'factory' header, where it joins the exhaust pipe. Any closer and it would have been a nightmare to get in. I use SAAS gauges and had the thermocouples tested by an instrument tech in his 'hot box' and confirmed the readings are correct for what is displayed. There are two probes and 2 gauges for total clarity. Response is very quick and more than adequate for what I wanted, which was actively managing the EGT's via driving style.
  11. #817
    Kindly received some pics today from http://www.blitsbodykits.com.au/ for the GU Supercharger bonnets if anyone needs raised @rainsey Cheers mate!
    I believe this one below is for GU4 and onwards: I believe this one below is for earlier:
    Wendy there was very helpful so give em a call if you GU blokes need.
  12. The Following 2 Users Say Thank You to MB For This Useful Post:
    PeeBee (5th October 2017), Ropes (22nd January 2021)
  13. #818
    Whoops forgot, they are ADR approved apparently with test certificates and each has its own specific registration number for your engineers needs was told.
  15. #819
    198 Post(s)
    I am considering swapping over to the Evans Waterless Coolant. I rang BD yesterday to find out the system volume and the number is 18 litres. Almost fell over. So the 20l of flush will be $379 and then 20L of coolant another $379
  16. The Following User Says Thank You to PeeBee For This Useful Post:
    MB (12th October 2017)
  17. #820
    And another 20L for $379 to carry as spare for when we accidentally stab a bottom end hose up in the hills mate :-)
