Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: How much wider gu diffs?
    Got the green light to save the pennies and work towards getting gu diffs and cvs as my front diff is rooted!
    How much wider are the diffs compared to Gq?
    Thinking about how much will they come out from the guards as my Flexi flares are bang on with my tyres at the moment.
    Not overly keen on getting new crazy wide flares to suit either!
  2. The Following User Says Thank You to AB For This Useful Post:
    Winnie (31st August 2017)
    Nasty Dog - Moderator Woof's Avatar
    Perth WA
    63 Post(s)
    Sorry mate cannot answer your question but everything on a GU is better tounge-animated-animation-boy-smiley-emoticon-000343-medium.gif
  4. The Following User Says Thank You to Woof For This Useful Post:
    jack (31st August 2017)
    Quote Originally Posted by Doggy View Post
    Oh god, traider!!!!
    You used to be cool Doggy
    I'm also worried about more scrubbing with the wider diffs too!
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Pity I threw out a good GQ diff a few years back , just kept the CV's and a few bits and pieces .
    Are GU diffs a bit stronger ?
    @MudRunnerTD has done this upgrade.
    It's mainly the better cvs and brakes from the gu.
  9. The Following User Says Thank You to AB For This Useful Post:
    GQtdauto (31st August 2017)
  10. #7
    They are stronger and also have bigger brakes. It's a really good upgrade, on my list to do down the track.
  11. #8
    334 Post(s)
    The GU CV is significantly bigger and well worth the upgrade. The brakes are a huge bonus.
    The length difference is a bit. Been a while but it was abo it a 40mm track change I believe so 20mm side.
    Given the track change yo u shou I'd be looking for a pair rather than just a front mate. You will get away with just a front but will suffer a little with rear steer, especially in the Beach Sand.
    You will need a new Drag Link and Tie Rod. I recommend a GU Steering Box too.
  12. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (31st August 2017), PeeBee (31st August 2017)
  13. #9
    334 Post(s)
    Obviously a weld on brace kit is a no brainer.
  14. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  15. #10
    334 Post(s)
    Also swapping your rims over for a lesser offset will sort out the extra track if your really concerned.
    Nissan factory rims off a GU will swap straight in and a cheap.
  16. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (31st August 2017), Rossco (31st August 2017)
