Page 406 of 570 FirstFirst ... 404405406407408 ... LastLast
Results 4,051 to 4,060 of 5693
  1. #4051
    334 Post(s)
    Might have bought another HiMount.............
  2. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    MB (22nd August 2017)
  3. #4052
    22 Post(s)
    And some long arms.
    96 GQ coil/Cab
    08 G6eT
  4. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    MudRunnerTD (22nd August 2017)
  5. #4053
    Another CAV Filter setup for under the vehicle to replace the in-line style ryco units - $70 delivered. Also bought a 12V band heater to wrap around the fuel filter to stop the paraffin drop out at low temps, as a couple of us experienced this last snow trip. Band heater is 250mm long x 50mm wide, heats the fuel to 65 deg C, and cheap - $30 delivered.
  6. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (23rd August 2017), Rossco (23rd August 2017)
  7. #4054
    Link please Phil mate :-) !
  8. #4055
    Yeah might have to do something with mine next frozen adventure. . . Yep had enough of fuel issues. . .
  9. #4056
    Heater element
    http://www.ebay.com.au/itm/50-X-250m...72.m2749.l2649
    CAV Filter assy
    http://www.ebay.com.au/itm/FFK2143-D...72.m2749.l2649
    The heater elements are avail in a wide variety. i will also be buying a 150mm x 150mm sq. self adhesive patch to stick on the side of the main tank, but this can wait. The heater on the front filter that was passed around is corca 330mm x 100mm but its about $165 to buy, so I think based on how effective and fast the pad heats up, this smaller unit would whip it, plus for the number of uses, its bargain buying I reckon - just have to wait 3 minutes instead of 2 i reckon. Just need to ensure the heater is temp limited as some on ebay heat to 300DgC plus for large bio-fuel tanks, and 12V
  11. #4057
    Your'e worse than me - where are you going to stick this one?
  12. #4058
    Before Rossco BEFORE the next one!
  14. #4059
    334 Post(s)
    Hopefully on the front of the GUIV
  15. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    PeeBee (23rd August 2017), Rossco (23rd August 2017), sooty_10 (24th August 2017)
  16. #4060
    Ah yes very good that would be quite wise . . .
  17. The Following User Says Thank You to Rossco For This Useful Post:
