Page 144 of 177 FirstFirst ... 142143144145146 ... LastLast
Results 1,431 to 1,440 of 1766
Thread: Ask all your general ( none related forum ) computer questions here
  1. #1431
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by Mike02Ti View Post
    Ok @NissanGQ4.2 click this link.
    It will download chainfire's Autoroot kernel.
    Please note that my instructions are for a windows based pc.
    Thanks, I'm windows based pc and downloading now and will give it a go later tonight
    Thanks..... hope this one works, I accidentally deleted my whole camera file but they where saved 2 phone memory, probably over written the info now anyway but still worth a go
  2. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    Mike02Ti (16th August 2017)
  3. #1432
    Aug 2010
    17 Post(s)
    Ok click this link.
    If no one has told you this recently... Your a bloody legend....
    Very simple 2 do using your method.
    Running DiskDigger app now 300 image / video files recovered already and only at 4%, there is hope yet
    I can't ever see myself in WA anytime in the near future but if your ever traveling 2 Sydney and are near the Blue Mountains get in contact I owe you a beer or 24
  4. The Following 3 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    jack (16th August 2017), Mike02Ti (16th August 2017), PeeBee (16th August 2017)
  5. #1433
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    No probs mate happy to help and i will take you up on that offer if im over that way
    2002 GUIII Ti 4.8
    Details here
  6. The Following User Says Thank You to Mike02Ti For This Useful Post:
    NissanGQ4.2 (16th August 2017)
  7. #1434
    https://download.chainfire.eu/958/CF...dd-smg900i.zip
    Step 2: extract to a folder. I usually put one on the desktop to make it easier.
    Step 3: in that extracted folder you will see a program called Odin. Right click and select run as administrator.
    Step 4: once Odin is open you will see some buttons down the right side. Click PDA and browse to the extracted folder. Select the tar.md5 file.
    Step 5: turn off your phone. Once its off completely hold power home and volume down til you see the screen come up. You should now be in download mode. Press volume up at the boot sreen.
    Step 6: now connect your phone to the pc. Odin should now recognize it. Make sure repartition is NOT checked. Click start and wait.
    Step 7: all done!!
    will this ecover from my sd card on the phone.??
    ive plugged sd card into pc but its not even recognizing it..
    Jun 2016
    Rockingham WA
    4 Post(s)
    @bigguwesty it might recover some. Only way would be to give it a try.
    Your device would need to be rooted too. But with a different file download. Same instructions though.
    The thing is the file system on the SD card is now basically in android form ( yes for all the tech heads out there i know its not entirely true) and its encryption is on there too. Makes it very hard to read just plugging the SD card into a pc.
    Best bet would be to root the phone and then via pc perform the recovery. Rooting the phone gives you unlimited access to the file system and allows the recovery software to run properly. Especially in the case of Wondershare software.
    The 2 programs i use mostly are Wondershare Dr Fone and Aiseesoft Android Data Recovery.
    Recuva I used sometimes as well. With these programs you can deep scan a lot more and its easier to see what is junk and whats not once the scans complete
    2002 GUIII Ti 4.8
    Details here
  9. The Following User Says Thank You to Mike02Ti For This Useful Post:
    BigRAWesty (16th August 2017)
  10. #1436
    Righto..
    Completely over my head with this..
    But im gunna give it a crack..
    Might have an "accident" if it goes south......
    Currently downloading all pics i have lol..
    So once programme is downloaded and phone hacked..
    Then what.
    Does that odian programe do whats needed, or do i have to run a recovery programe to do the work?
    I think ill attemp this tomorrow night lol..
    Edit- wondershare isnt even recognizing the phone, yet the cp is. is has also found the sd card via the phone, but not via sd reader..
    Jun 2016
    Rockingham WA
    4 Post(s)
    No the odin program is to "hack" the phone. Thats all it does.
    You will need to run the recovery program after you do the hacking so to speak
    The recovery programs easy. Pretty much click a button and wait.
    Whats the exact model number of your phone? I can give you the download link for the hacking
    2002 GUIII Ti 4.8
    Details here
  12. The Following User Says Thank You to Mike02Ti For This Useful Post:
  13. #1438
    Aug 2010
    17 Post(s)
    Righto..
    Then what.
    Odin won't recover you will still need an app or program, look up diskdigger in the playstore
    I don't believe the Wondershare program supports phones
  14. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  15. #1439
    Im running the new S8
    Jun 2016
    Rockingham WA
    4 Post(s)
    Ahhh right ok this just got a bit harder cos the software is so new. On the back in small writing is the the model number starting with SM followed by 3 numbrs and a letter. What is that?
    2002 GUIII Ti 4.8
    Details here
