Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 65
Thread: LRA GQ LWB auxiliary fuel tank install manual
  1. #41
    If your throwing the sub filler in the same hatch as the main grab the steel tube setup off a gu.
    Yep, Patrolapart said they are a bit of a nightmare and can pretty much wipe off half a Saturday.
  3. #43
    Feb 2016
    Has anyone ever had a issue with forgetting to turn the aux pump off and running it dry?
  4. #44
    .......... TPC's Avatar
    63 Post(s)
    Quote Originally Posted by shoey50 View Post
    What Patrol do you have? In my GU I believe it automatically shuts the pump off when the sub is transfered to the main.
  5. #45
    He's probably talking GQ tony replying to this thread.
  6. #46
    Yes I did it a few times at the start forgetting to turn it off, the pumps don't like running dry either, overheats, etc.
    One best way is to fill the aux tank up, do a full pump to a main tank in your carport and time it and use your timer whilst touring to remind you.
  7. #47
    63 Post(s)
    Oops, I should reed the title of the thread.
  8. The Following User Says Thank You to TPC For This Useful Post:
    AB (30th July 2017)
  9. #48
    Yeah I know mine takes about 40 mins to transfer fully, so I set my phone as a timer at 35 mins and turn the pump off at that time.
  10. #49
    About to wire mine back all up. . . Hope it all works
  11. The Following User Says Thank You to Rossco For This Useful Post:
    BigRAWesty (3rd August 2017)
  12. #50
    So anyone want a gq tank?
    Mudrunner gave me one a while back that needed repair.
    Repair has been done but it needs the strap mount to swing arm mount.
    Basic bit of flat bar with a hole.
    Sender is shot but there.
    Clean inside.
    Only down fall is its in mt gambier lol..
