Page 781 of 1057 FirstFirst ... 779780781782783 ... LastLast
Results 7,801 to 7,810 of 10561
  1. #7801
    198 Post(s)
    Fitted the fuel flowmeters and computer today, no correlation between the programming instructions and whats on the actual screen, completly different so a call to the vendor required to get it set up.
    Removed the original Safari Snorkle and cut the hole for the new SS 4" unit. Its not a pretty outcome as the original hole cut by ARB is huge for reasons unknown, and the 3 off mounting holes, they are at least 22mm dia for m10 bolts - I understand they don't have time for fancy fitting up, but this is disgraceful to be honest. In fairness I guess you would never see them, but I can see the damn things now! I have fitted black rubber grommets and its acceptable, but the bigger hole under the 4" bend is going to be a panel beaters job I reckon. Quite a cavity below the elbow, makes me wonder how the likes of Patrol a part and Millweld sort this out.
  2. #7802
    198 Post(s)
    Just looking at brown davis..
    Fit a 2" body lift and you can carry 252L of of fuel...
    Or 210L if its standard height.....
    I take it this is with two tanks? I have 220L on board already across 2 tanks, but lifting the body for the additional 30L wouldn't be justified I reckon for me.
  3. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    BigRAWesty (29th July 2017), Winnie (29th July 2017)
  4. #7803
    Uea thats 2 tanks.
    160 main and 90 sub for body lift.
    140 main and 70 sub for standard..
    I only have 150 atm in factory tanks (modded rear main to fit 110).
    What tanks are you running to achieve 220L?
    198 Post(s)
    Uea thats 2 tanks.
    Both Brown Davis units, 147 rear and 75 Belly. Good tanks, were expensive at the time I bought them as the price has hardly gone up from 1997 till now, but saying that, they have been trouble free until I fitted the 6.5 and then had issues with the draw from the belly tank - its fitted with a 1/4" outlet hoes whilst the main is 5/16", and the motor starves, so have converted it to transfer fuel back to the main tank, problem fixed.
  6. The Following User Says Thank You to PeeBee For This Useful Post:
  7. #7805
    Yea they are made to keep the factory transfer setup..
    Are the alloy plated sheet or just mild steel do you know?
    198 Post(s)
    Even back then, BD had moved to the plated material. I did punch a hole in the rear tank but simply emptied it at home and patched it. The set-up he sold and probably still sells is the multi port selector valve. I have only had one die in all that time, so a very reliable setup.
  9. #7807
    Expert Skitzyrex's Avatar
    Jul 2013
    After repeatedly bending up my trailer socket on the old bracket I decided to buy a new one and put it in the bumper.
    2007 GU ST-S 4.8 Patrol.
    40mm heavy duty springs, Dual batteries,
    140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
  10. The Following 2 Users Say Thank You to Skitzyrex For This Useful Post:
    BigRAWesty (30th July 2017), Clunk (29th July 2017)
  11. #7808
    Aug 2014
    Perth
    10 Post(s)
    Fitted up a flush mount RJ45 socket for my Icom UHF and also a RAM IPad mount using the seat rail bolt.
  12. #7809
    198 Post(s)
    Got my spare set of Koni's reco'd and swapped them out in the rear - fronts next weekend, too stuffed plus pressure to 'get out from under that bloody car' from 'you know who - the cushion queen'.
  13. The Following 5 Users Say Thank You to PeeBee For This Useful Post:
    GQtdauto (30th July 2017), TPC (30th July 2017), VK2FMIA (5th August 2017), Winnie (30th July 2017), Yeti's Beast (31st July 2017)
  14. #7810
    Quote Originally Posted by Skitzyrex View Post
    Mine has been smashed after the trip and i hate the flat plug.
    So will be doing the same and mounting a round plug socket on the bumper..
  15. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Skitzyrex (30th July 2017)
